Ansys Learning Forum Forums Discuss Simulation 3D Design Select a curve for creating tube script Reply To: Select a curve for creating tube script
Atharv Joshi
So here you need to make changes the following changes and try.
Ensure that you can in 3D mode before running the script.
curveSelList = Selection.Create(GetRootPart().Curves[0])
result=TubeBody.Create(curveSelList,MM(5),ExtrudeType.Add)
You can also make the selection with the help of Curve Selection commoand.
curveSelList = CurveSelection.Create(GetRootPart().Curves[0])
Regards
Atharv
