September 15, 2024 at 1:07 pm
paaulocz
SubscriberHi,
I am working with fluid-thermal-structural analysis and would like to learn about the most suitable workflow in Workbench. In fluid-structure FSI analysis with strong coupling (two-way coupled), the most common approach is:
However, in my solid domain, I have heat flux and pressure as external loads, so I imagine it is necessary to also use the thermal module. In this case, would it be more appropriate to use something like: Fluent + Coupled Field (thermal-structural) + System Coupling?
Thank you in advance!
September 18, 2024 at 11:18 am
Rahul
Ansys EmployeeHello
Yes, as you need pass both structural and thermal data. Using Fluent-Coupled Field transient coupling with System Coupling would be more appropriate workflow.You can refer user guide for more information:Â Supported Coupling Participants for System Coupling in Workbench (ansys.com)Â
5149
1836
1387
1248
