Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Node 999999 Fatal signal raised sig = Segmentation fault › Reply To: Node 999999 Fatal signal raised sig = Segmentation fault
September 15, 2024 at 2:56 am
z5456415
Another issue I am facing is the "bad termination of one of your application processes" error. I used 4 solver processes to run the simulation. Is this error because of any settings change in Ansys? Also, please note that the files are synced between one drive and the laptop. However the working directory is in onedrive.
