Ansys Learning Forum › Forums › Discuss Simulation › Electronics › 3um width and 2 um spacing Differential lines using HFSS 3D › Reply To: 3um width and 2 um spacing Differential lines using HFSS 3D
September 13, 2024 at 12:38 pm
Thank you for reaching out to the Ansys learning forum.Â
Please go through Differential Microstrip example project availabe under Open Examples > HFSS > Transmission lines if you are implementing in microstrip. This project also contains one PDF describing the model.
Hope this helps.
Best regards,
Praneeth.
