Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Reaction forces and moments during random vibration at local coordinate systems › Reply To: Reaction forces and moments during random vibration at local coordinate systems
Sorry. As I said, I never tried it myself. The way FSUM is performed for a PSD it actually could support RSYS, but apparently that wasn't enabled. For a spectrum analysis the FSUM is performed on each mode separately and the modal fsum values are recombined. I found that FSUM moments aren't in the local coordinate system even if you rotate the node, so that's not a workaround. You could get the moments in a local coordinate system for an individual mode using RSYS and FSUM,RSYS and a mode factor equal to the square root of the variance.
