September 10, 2024 at 7:47 pm
kirthika
SubscriberHiÂ
I simulated 3um width differential lines with 2um spacing on 1um SiO2 and 100um Silicon using HFSS 3D.Â
I have attached the E-field from the simulation, which sees a total reflection away from the substrate. So the simulation is not right.
How do I set up the simulation right? I do not see this issue in ADS Momentum.Â
September 13, 2024 at 12:38 pm
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum.Â
Please go through Differential Microstrip example project availabe under Open Examples > HFSS > Transmission lines if you are implementing in microstrip. This project also contains one PDF describing the model.
Hope this helps.
Best regards,
Praneeth.
