September 10, 2024 at 10:27 am
vishalvermaiitj
SubscriberA object having mass of 40kg is moving linealy with velocity 20m/s. This has to be stopped within available distance of 3 meter. To do the same two rubber plate has been installed in front of object with a nose. When object hit the nose, it will enter into rubber passage which will offer frictional resistance to the obeject. Object is safely stopping but the hourglass energy and contact energy are too much and internal energy is too less, which result into less frictional heat, how to reduce hourglass energy and contact energy in this problem
September 10, 2024 at 10:37 am
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
1494
1386
1209
