Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDF for mass-flow-inlet › Reply To: UDF for mass-flow-inlet
September 9, 2024 at 3:15 pm
Boundary conditions are used for a surface effect, ie an inlet/outlet/wall and the like. If you need to add (or remove) material from a cell zone (volume effect) then you need a source term. What effect are you trying to replicate? Have you done some/most of the tutorials as those will give you a good idea of how the solver works.Â
