Ansys Learning Forum Forums Discuss Simulation General Mechanical coupled field harmonic analysis with pretension Reply To: coupled field harmonic analysis with pretension
N1129070
thanks for your answer. Yes, I work with the full harmonic. But in my case, the non-zero displacement (in coupled field static) always acts as harmonic load in coupled field harmonic analysis.
may I send my case to you?
