October 4, 2019 at 5:43 pm
koltesomesh20
SubscriberIs their difference in velocity distribution in porous media and empty pipe. I am doing simulation using physical velocity in porous media. But i can't see the difference in velocity in porous media and without porous media section
October 7, 2019 at 3:56 pm
Forum ModeratorWhat resistance coefficients did you set? Please plot contours of velocity to illustrate the problem.
October 7, 2019 at 3:58 pm
DrAmine
Ansys EmployeeUsing superficial velocity formulation you will only see pressure drop. -
October 8, 2019 at 6:01 am
koltesomesh20
SubscriberI am using physical velocity formulation in cell zone condition but there is no velocity change. i can see only pressure drop. i am using standard initialization. If I am wrong please correct me.
October 8, 2019 at 6:03 am
koltesomesh20
Subscriberviscous resistance 4.09e+10 and inertia resistance 107306.7
October 8, 2019 at 8:32 am
DrAmine
Ansys EmployeeCan you plot path-lines colored by velocity magnitude through the porous zone.
October 8, 2019 at 6:20 pm
koltesomesh20
SubscriberI had plot streamlines for velocity but their is no difference in colour and magnitude -
October 10, 2019 at 2:00 pm
Forum ModeratorPlease post the images, pressure drop and velocity. Also please add any solutions on here rather than keeping them to yourself!
October 11, 2019 at 11:13 am
koltesomesh20
Subscriberhi..I got the solution. Use physical velocity in fluid dialogue box. And also use only standard initialization if u use habride initialization u will not reach to actual solution
October 11, 2019 at 2:36 pm
koltesomesh20
SubscriberWhen porous material in thermal equilibrium with fluid. Can we get temperature drop in fluid along the pressure drop????
October 11, 2019 at 2:44 pm
Forum ModeratorHave a look in the contours.
October 22, 2019 at 5:47 am
koltesomesh20
Subscriberis their someone working in refrigerant flow through porous media????
I need some help please....
October 22, 2019 at 11:13 am
Forum ModeratorMaybe add some images? Amine and I have suggested a few plots, sharing those would help us understand what you're doing.
- The topic ‘Porous media’ is closed to new replies.
5664
1890
1419
1304
