errors with running Fluent on HPC clusters
    • ehkh
      I get the following errors when I send an ansys instruction file and a transient case file to linux HPC:
      Error: File has wrong dimensions (3).
      Error Object: #f
      Error: Error reading "Triang.cas".
      Error Object: #f
      Error: CAR: invalid argument [1]: wrong type [not a pair]
      Error Object: ()
      also, the output file shows Invalid command for all of the commands lines
      I prepared the case file with the models and boundary conditions and uploaded to the HPC, I also tried the following instruction in fluent console on local windows machine and they worked very well but not working on linux HPC.
      /file/read-case Triang.cas
      /solve/initialize/initialize-flow
      /adapt/mark-inout-hexahedron yes no 0.0 0.05 -0.001 0.0 0.0 0.01
      /solve/patch air , hexahedron-r0 , mp 1
      /solve/dual-time-iterate 1000000 200
      /file/write-case-data TriangResults
      /exit
      Could you please help me how to resolve this. please note that I am using ANSYS 19.2 on both machines.
      Thanks
      Esra'a
    • ehkh
      Hi, I also tried to run the case file for one iteration on windows machine to get a data file and then upload the case and data file to linux HPC, using the following instructions:
      /file/read-data Triang.dat
      /solve/set/time-step 0.0001
      /exit
      and I also get the following errors:
      Error Object: #f
      Error Object: #f
      > invalid command [read-data]
      > invalid command [dual-time-iterate]
      > invalid command [set]
      > invalid command [write-case-data]
    • ehkh
      I appreciate any help regarding the previously mentioned errors.
      Thanks,
      Esra'a
      The dimension error means you're trying to read a 3d file into the 2d solver; the rest are following from the solver not having anything loaded.
  • The topic ‘errors with running Fluent on HPC clusters’ is closed to new replies.
