Preprocessing
Preprocessing
Error in importing mesh to CFX
    • ahmadzaki
      I used ANSYS mesher to create a structured mesh for a building inside a domain. To do that I had to slice the surfaces and then combine all the parts as a single part, then mesh it as multizone. Here it is:
      The meshed domain worked fine in FLUENT; however, when I tried to import it to CFX (and yes I changed the preference to CFX before doing that) it gave me the following error and failed to import the meshed domain:
      Application Error in CFX-Pre: ERROR
      Attempt to create an interface map between non-matching face meshes:
      Vertices Faces Face mesh Region [Base name]
        Side 0:         81         64 H9f+L+kRiOX0qEWKpG5nFA F3091.2660
                                                             [F3091.2660]
        Side 1:         88         70 VDkBMOkRiOX0qJuLpG5nFA F3091.2678
                                                             [F3091.2678]
      Unable to import the requested mesh:
      Type             = "GTM_PARTIAL_DSDB".
      File             = "E:Model 2_grid snsmodel2_filesdp0SYSMECHSYS1.cmdb".
      Generic  options = " -model 0".
      Specific options = "-contact read -names 'CFXMesh ACMO_Simulation'".
      Thank you for your support
Viewing 0 reply threads
  • The topic ‘Error in importing mesh to CFX’ is closed to new replies.
