Ansys Products
Ansys Products
ICEM CFD 2019 R2 Help Fails
    • lcoolidg
      ICEM CFD 2019 R2 Help Fails and generates the following error:
      Couldn't change working directory to "~": No such files of directory
    • tsiriaks
      Could you post the screenshot of this ?
      It sounds like you point to the local install of help documentations. Did you install help locally (this is separate install than the main software) ?
      Otherwise, you can access the online help (need portal login) https://ansyshelp.ansys.com
    • lcoolidg
    • lcoolidg
      Here's a screen shot of the error.  I expected clicking on help within ICEM to take me to the on line documentation like workbench does in this installation.  I did not do a separate install of ICEM locally.  Thanks
    • tsiriaks
      If you open CMD Prompt, then issue the following command
      "%icemcfd_root194%..commonfileshelpHelpViewerANSYSHelpConfigurationTool.exe"
      is it set to online help or local help ?
    • lcoolidg
      It is set to online help. This was the default, I did not change it.
       I wanted to emphasize that within ICEM CFD if you select help is locks up the session and your have to close the program.  So what ever is coded behind the help button needs to be fixed.  Help from workbench functions normally going to web help.
      Thanks for your help.
      Larry
    • tsiriaks
      I can't reproduce the issue.
      What if you do File -> Change Working Directory -> Then, specify C:Temp and try launching Help again ?
    • lcoolidg
      I Changed Working Directory to C:Temp and got same failure/lockup.  see attached screen shot
    • tsiriaks
      Hmm, not sure why it's trying to change working directory to ~
      Can you post the output of the 'set' command (no quote ' ')  from the CMD Prompt ?
    • lcoolidg
    • lcoolidg
      see attached file set.txt
    • tsiriaks
      ANSYS employee is not allowed to download or open this attachment
      Could you post an in-line screenshot of it ?
    • lcoolidg
      here is jpg of set
      thanks
      Larry
    • tsiriaks
      The issue is with your HOMEDRIVE and HOMEPATH , which are combined to point to U:
      Can you change this to be a local directory ?
      If you want to test first if it really helps, you can open CMD Prompt, then issue the following commands
      set HOMEDRIVE=C:
      set HOMEPATH=temp
      "%awp_root194%icemcfdwin64_amdbinicemcfd.bat"
      then, launch Help from here.
    • lcoolidg
      tsiriaks:
      set HOMEDRIVE=C:
      set HOMEPATH=temp
      that solved the problem so I edited the "%awp_root194%icemcfdwin64_amdbinicemcfd.bat" and added the above two lines to the bat file.
      good job you can close this post as solved
      thanks
      Larry
    • tsiriaks
      Hi Larry,
      That's good to hear.
      Thanks for the confirmation.
      Win
Viewing 15 reply threads
  • The topic ‘ICEM CFD 2019 R2 Help Fails’ is closed to new replies.
