August 27, 2024 at 11:48 am
sudhakar917
SubscriberHi,
The geared rotor is supported on the journal bearings on either side. I would like to estimate the expansion of gearwheel under various speeds.Â
Is it ok to use cylindrical support as B.C (boundary condition) in the region of journal bearing?
Thanks,
Sudhakara
August 28, 2024 at 1:24 pm
Ashish Khemka
Forum Moderator -
August 29, 2024 at 11:12 am
sudhakar917
SubscriberHi,
I have carried out the analysis with cylindrical supports – the expansion is 90 microns.
The same analysis with journal bearing (with stiffness & damping properties ) gave 220 microns of expansion.
I am not able to comprehend the deviation in results.
Please clarify, which support is correct.
Sudhakara
August 29, 2024 at 12:07 pm
Ashish Khemka
Forum ModeratorHi,
Did you turn on the large deflection? If not then please try turning on the large deflection under analysis settings.
Ashish Khemka
5964
1307
