August 24, 2024 at 5:01 am
anindya
SubscriberDear Experts, I have already created a complex design using FDTD, and now I need to change the axis symmetry (for example: converting the y-axis into the x-axis, z into y, and x into z). Is there a way to do this after the design is completed? Please suggest a solution for this issue. Thanks and regards, Anindya Bose
August 26, 2024 at 4:00 pm
Guilin Sun
Ansys EmployeeThis is the same as this one Method to swap axis (exchange axis)Â and will be closed. Please avoid posting the same question in the forums.
- The topic ‘A process to change the axis orientation’ is closed to new replies.
1343
1152
