Ansys Free Student Software
Distributed solver
    • kolyan007
      I'm playing with Distributed solving in version 19.4 R2. My cluster has 3 PCs. In a couple minutes after Solver started the job has failed.
      I can't find what caused it. Could you please review log file and advise?
      Thanks, Nick
    • tsiriaks
      Hi Nick,
      Sorry, ANSYS employees are not allowed to download file attachments. Could you post this as an inline text or post screenshots inline ?
      Are you using ANSYS Student (free) version ?
      Is this Mechanical, Fluids, or Electronics product ?
      Thanks,
      Win
      Win, it looks like a directory error.
    • kolyan007
      Thanks Peter, good spotting. That folder ScrCA9A is missing under _ProjectScratch. How I can find why Mechanical trying to access it? Could it be because of some references in projects?
    • tsiriaks
      Thanks for the screenshot Peter.
      So, this is Mechanical + ANSYS RSM.
      I'm gonna need much more information to proceed. Note: That folder should be automatically created by the solver.
      When you said 'cluster' , do you mean it has job scheduler or it's just 3 machines with no job scheduler connecting to each other ? If you have your own scheduler, what's the name of it ?
      How do you submit the jobs ? Please show screenshots of the workflow and setup in both Workbench and RSM Configuration GUI's
      Post screenshot of the top part of RSM Job Report.
      Thanks,
      Win
    • kolyan007
      Thanks for your reply. I was thinking there is some incompatibility between my 3 machine cluster and R2, so I did reinstall OS on master machine (maincad) that using to send tasks to slaves in cluster, install R3 on it and install R3 on slaves, then replicate settings.
      I don't have my own scheduler. All machines connecting to each other.
      There are a screenshots with my config below.
      ARC configuration on master
      ARC configuration on masterARC configuration on masterARC configuration on master
      Note: I'm not sure why, but Service Management running by cluster02user. Not sure how to change to default.
      RSM config on master:
      RSM configuration on master
      RSM configuration on masterRSM configuration on master
      Somehow Queues refresh fails.
      This is after I deleted credentials for cluster01
      RSM config for cluster02
      And RSM config for localhost
      These 3 services running on each machine in cluster:
      Master:
      Services on master
      Cluster01
      Services on cluster01
      Cluster02
      Services on cluster02
      My Solve Process settings:
      Solve settings
      Solve in mechanical
      Also I've tested telnet to port 9195 and SMB in Windows, there is no issues from OS perspective. All machines using same credentials.
      Additionally I've found that if I run: arcconfig node modify %COMPUTERNAME% -mn maincad                  so test in RSM will go in schedule mode, but if I replace my master node with %COMPUTERNAME%, a test will go through fine. What options is correct?
      Cluster01 port 9195 listening
      Cluster02 port 9195 listening
    • tsiriaks
      ok, so you are using ANSYS own light-weight scheduler (ARC).
      I normally use commands to set this, so I'm not familiar with settings on the ARC Config GUI but I've asked a colleague to help check it.
      However, I see a lot of mis-configurations.
      Essentially, this is what you need to do to properly setup RSM-ARC
      Create share directory
      Create a directory on a machine that you would like to use as the staging directory.
      For this example, I will use e:RSMStaging
      Now share that directory out to all solving machines and 'submit host' so that anyone can read and write to it.
      Right click on RSMStaging and select Properties Select Sharing Tab
      Click on Share...
      Type in:
      Everyone
      And click Add
      Type in:
      Domain Computers
      Click Add
      Type in:
      Domain Users
      Click Add
      Give each of the users Read/Write access
      Then click "Share"
      Then click Done
      On 'submit host' machine (This is a dedicated node. Do not install this on all nodes)
      This is the machine that receives requests from clients, then queues and distributes jobs to solve on solving machines. This machine itself can also be a solving machine.
      Two components are required here:
      1. RSM Launcher service, which deals with the communications between client machine and this machine
      2. ARC Master service is one of the two parts of the ARC job scheduler, a light-weight job scheduler that ANSYS provides. This part deals with the communications between RSM Launcher and solving machine(s) , essentially, queueing and distributing jobs to solving machine(s).
      On solving machine(s)
      Install ARC Node service, which is used for communicating with the ARC Master service.
    • JakeC
      Hi Nick,
      There seems to be a number of different issues to look at here.
      First, please uninstall the ARC Master and RSM Launcher services from the two machines that are NOT the head node.
      You can do this from the command line by doing the following:
      Start -> Type cmd -> Right click on Command Prompt and select Run As administrator
      At the prompt type:
      cd /d "c:program filesansys incv195RSMbin"
      ansunconfigrsm -launcher
      cd /d "c:program filesansys incv195RSMARCtoolswinx64"
      uninstallservice -arcmaster
      This should leave the ARC Node service running on MainCad,Cluster01,Cluster02
      This should leave the ARC Master and Launcher service running on MainCad only.
      Once that is done, go to MainCad and run the admin command prompt as state above, then type:
      cd /c "c:program filesansys incv195RSMARCtoolswinx64"
      arcnodes
      arcqueues
      Then please paste a screenshot of that.
      Thank you,
      Jake
    • tsiriaks
      Continued
      On client machines. Note All info here is the same on any client machine. The Submit Host is the dedicated node above. Do not use local machine information.
      Launch RSM Configuration GUI
      Once you are in the GUI, click the plus sign on the top left then fill out name or its IP address of the Submit Host machine and OS.
      Once, this is done, click “Apply”
      Go to “File Management” tab , Select "Operating System File Transfer" , Put in the share path to the RSMStaging directory you shared earlier (again, this is the same UNC path that you setup to share above, do not use local machine information)
      Then, Go to “Queues” tab , click “Import/Refresh Cluster Queues” , then specify your login username and password. This will bring up all the queues. You can enable and disable any queue that you like.
      Then make sure that port 9195 is open between the client and the ‘submit host’ machines.
    • tsiriaks
      sounds good, please keep us posted
      Thanks,
      Win
    • kolyan007
      Just checked RSM Cluster Load Monitoring on HEAD node, it shows only 1 node, not 3. I've manually created another queue and added another nodes to it, but it doesn't help.
      My queues and RSM Cluster output on HEAD node is below:
    • kolyan007
      Followed ANSYS RSM user guide to finalize my cluster setup.
      Got 3 nodes under RSM Cluster Monitoring and tests were fine, but there is an error when I tried to solve my project. Maincad is my Submit Host+solver, Cluster02 is only solver. Please advise what could be wrong?
    • JakeC
      Looks like something is blocking the IntelMPI processes.
      Firewall / User Account Control / Antivirus / etc...
      You could try IBM MPI instead.
      First make sure IBM/Platform MPI is installed on all machines.
      Then In Mechanical go to Solve Process Settings -> Select your config -> Advanced
      In the Additional Command Line Arguments add:
      -mpi ibmmpi
      Then try it again.
      Thank you,
      Jake
    • kolyan007
      Thanks for advise. I've installed MPI services only on Submit host. I will add it to remote solvers and add these CMD arguments.
    • kolyan007
      What arguments should I use if I will be using Intel MPI? (once MPI installed on all machines)
      What installation set of IBM MPI would be the best for Windows 10? (Service Mode, Service Only or HPC mode)
    • kolyan007
      Right, so IBM MPI is installed on all machines as Service Mode, hope it's correct set. Also -mpi ibmmpi as argument also added. Telnet to TCP 8636 from Submit Host to solvers is ok.
      Now solving working, but I don't see any CPU load on my solvers. If there anything else to check?
      Start running job commands ...
      Running on machine : Maincad
      Current Directory: c:RSMStagingofwkpry5.3rq
      Running command: C:Program FilesANSYS Incv195SECSolverExecutionControllerrunsec.bat
      Redirecting output to  None
      Final command arg list :
      Running Process
      Running Solver : C:Program FilesANSYS Incv195ansysbinwinx64ANSYS195.exe -b nolist -s noread -p ansys -mpi ibmmpi -i remote.dat -o solve.out -dis -machines maincad:1:cluster01:1:cluster02:1 -dir "cRSMStaging/ofwkpry5.3rq"
      WARNING: No cached password or password provided.
               use '-pass' or '-cache' to provide password
       *** The AWP_ROOT195 environment variable is set to: C:Program FilesANSYS Incv195
       *** The AWP_LOCALE195 environment variable is set to: en-us
       *** The ANSYS195_DIR environment variable is set to: C:Program FilesANSYS Incv195ANSYS
       *** The ANSYS_SYSDIR environment variable is set to: winx64
       *** The ANSYS_SYSDIR32 environment variable is set to: intel
       *** The CADOE_DOCDIR195 environment variable is set to: C:Program FilesANSYS Incv195CommonFileshelpen-ussolviewer
       *** The CADOE_LIBDIR195 environment variable is set to: C:Program FilesANSYS Incv195CommonFilesLanguageen-us
       *** The LSTC_LICENSE environment variable is set to: ANSYS
       *** The P_SCHEMA environment variable is set to: C:Program FilesANSYS Incv195AISOLCADIntegrationParasolidPSchema
       *** The TEMP environment variable is set to: C:UsersUserAppDataLocalTemp
    • tsiriaks
      This seems good (and by the way, the Service Mode for IBM MPI is the correct choice) .
      If you open up Task Manager on solving machines do you see any ANSYS.exe or ANSYS195.exe ?
    • kolyan007
      Only Submit host has some activity with ANSYS, solvers don't show it. Weird.
      This screenshot from Submit host:
    • JakeC
      Please post a screenshot of your Solution properties if submitting from workbench or post the screenshot of your Solve Process Settings and the advanced tab for the solve process setting you are using.
      Thank you,
      Jake
    • kolyan007
      Yesterday I was playing with Intel MPI as previously I've seen some load on solvers with it. The screenshot with Solve Process Settings and Advanced tab is below.
      So I've tried with -mpi intelmpi argument and without. The result was the same, i.e. the solving process started on all machines, CPU load was 100% but only for a couple of minutes, then I got MPI_Abort error (full error message is also below).
      Note: Regarding that Invalid working directory value= CRSMStaging/aokqqj0p.5k1 message it's weird as folder actually exists and accessible by solvers. Not sure why it has wrong slashes here.
      Also, I do have NVidia Quadro GPU in each machine. Is it reasonable to enable GPU Acceleration to improve performance?
      Error message (omitted):
      send of 20 bytes failed.
      Command Exit Code: 99
      application called MPI_Abort(MPI_COMM_WORLD, 99) - process 0
      [mpiexec@Maincad] ..hydrautilssocksock.c (420): write error (Unknown error)
      [mpiexec@Maincad] ..hydrautilslaunchlaunch.c (121): shutdown failed, sock 648, error 10093
      ClusterJobs Command Exit Code: 99
      Saving exit code file: C:RSMStagingaokqqj0p.5k1exitcode_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
          Exit code file: C:RSMStagingaokqqj0p.5k1exitcode_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout has been created.
      Saving exit code file: C:RSMStagingaokqqj0p.5k1exitcodeCommands_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
          Exit code file: C:RSMStagingaokqqj0p.5k1exitcodeCommands_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout has been created.
      =======SOLVE.OUT FILE======
      solve -->  *** FATAL ***
      solve --> Attempt to run ANSYS in a distributed mode failed.
      solve -->   The Distributed ANSYS process with MPI Rank ID =    4 is not responding.
      solve -->   Please refer to the Distributed ANSYS Guide for detailed setup and configuration information.
      ClusterJobs Exiting with code: 99
      Individual Command Exit Codes are: [99]
      Full error log:
      RSM Version: 19.5.420.0, Build Date: 30/07/2019 57:06 am
      RSM File Version: 19.5.0-beta.3+Branch.release-19.5.Sha.9c15e0a3e0a608e8efe8c568e494d2160788d025
      RSM Library Version: 19.5.0.0
      Job Name: Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
          Type: Mechanical_ANSYS
          Client Directory: C:TestProject_ProjectScratchScr6531
          Client Machine: Maincad
          Queue: Default [localhost, default]
          Template: Mechanical_ANSYSJob.xml
      Cluster Configuration: localhost [localhost]
          Cluster Type: ARC
          Custom Keyword: blank
          Transfer Option: NativeOS
          Staging Directory: C:RSMStaging
          Delete Staging Directory: True
          Local Scratch Directory: blank
          Platform: Windows
          Cluster Submit Options: blank
          Normal Inputs: [*.dat,file*.*,*.mac,thermal.build,commands.xml,SecInput.txt]
          Cancel Inputs: [file.abt,sec.interrupt]
          Excluded Inputs: [-]
          Normal Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,secStart.log,sec.validation.executed,sec.envvarvalidation.executed,sec.failure]
          Failure Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,sec.solverexitcode,secStart.log,sec.failure,sec.envvarvalidation.executed]
          Cancel Outputs: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
          Excluded Outputs: [-]
          Inquire Files:
            normal: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,secStart.log,sec.validation.executed,sec.envvarvalidation.executed,sec.failure]
            cancel: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
            failure: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,sec.solverexitcode,secStart.log,sec.failure,sec.envvarvalidation.executed]
            RemotePostInformation: [RemotePostInformation.txt]
            SolutionInformation: [solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
            PostDuringSolve: [file.rcn,file.redm,file.rfl,file.rfrq,file.rmg,file.rdsp,file.rsx,file.rst,file.rth,solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
            transcript: [solve.out,monitor.json]
      Submission in progress...
      Created storage directory C:RSMStagingaokqqj0p.5k1
      Runtime Settings:
          Job Owner: MAINCADUser
          Submit Time: Tuesday, 8 October 2019 11:40 pm
          Directory: C:RSMStagingaokqqj0p.5k1
      Uploading file: C:TestProject_ProjectScratchScr6531ds.dat
      Uploading file: C:TestProject_ProjectScratchScr6531remote.dat
      Uploading file: C:TestProject_ProjectScratchScr6531commands.xml
      Uploading file: C:TestProject_ProjectScratchScr6531SecInput.txt
      39898.74 KB, .08 sec (498807.21 KB/sec)
      JobType is: Mechanical_ANSYS
      Final command platform: Windows
      RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
      RSM_HPC_JOBNAME=Mechanical
      Distributed mode requested: True
      RSM_HPC_DISTRIBUTED=TRUE
      Running 1 commands
      Job working directory: C:RSMStagingaokqqj0p.5k1
      Number of CPU requested: 12
      AWP_ROOT195=C:Program FilesANSYS Incv195
      Checking queue default exists ...
      JobId was parsed as: 4
      Job submission was successful.
      Job is running on hostname Maincad
      Job user from this host: User
      Starting directory: C:RSMStagingaokqqj0p.5k1
      Reading control file C:RSMStagingaokqqj0p.5k1control_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsm ....
      Correct Cluster verified
      Cluster Type: ARC
      Underlying Cluster: ARC
          RSM_CLUSTER_TYPE = ARC
      Compute Server is running on MAINCAD
      Reading commands and arguments...
          Command 1: %AWP_ROOT195%SECSolverExecutionControllerrunsec.bat, arguments: , redirectFile: None
      Running from shared staging directory ...
          RSM_USE_LOCAL_SCRATCH = False
          RSM_LOCAL_SCRATCH_DIRECTORY =
          RSM_LOCAL_SCRATCH_PARTIAL_UNC_PATH =
      Cluster Shared Directory: C:RSMStagingaokqqj0p.5k1
          RSM_SHARE_STAGING_DIRECTORY = C:RSMStagingaokqqj0p.5k1
      Job file clean up: True
      Use SSH on Linux cluster nodes: False
          RSM_USE_SSH_LINUX = False
      LivelogFile: NOLIVELOGFILE
      StdoutLiveLogFile: stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
      StderrLiveLogFile: stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
      Reading input files...
          *.dat
          file*.*
          *.mac
          thermal.build
          commands.xml
          SecInput.txt
      Reading cancel files...
          file.abt
          sec.interrupt
      Reading output files...
          *.xml
          *.NR*
          CAERepOutput.xml
          cyclic_map.json
          exit.topo
          file*.dsub
          file*.ldhi
          file*.r0*
          file*.r1*
          file*.r2*
          file*.r3*
          file*.r4*
          file*.r5*
          file*.r6*
          file*.r7*
          file*.r8*
          file*.r9*
          file*.rd*
          file*.rst
          file.BCS
          file.ce
          file.cm
          file.cnd
          file.cnm
          file.DSP
          file.err
          file.gst
          file.json
          file.nd*
          file.nlh
          file.nr*
          file.PCS
          file.rdb
          file.rfl
          file.spm
          file0.BCS
          file0.ce
          file0.cnd
          file0.err
          file0.gst
          file0.nd*
          file0.nlh
          file0.nr*
          file0.PCS
          frequencies_*.out
          input.x17
          intermediate*.topo
          Mode_mapping_*.txt
          post.out
          record.txt
          solve*.out
          topo.err
          toput
          vars.topo
          SecDebugLog.txt
          secStart.log
          sec.failure
          *.xml
          *.NR*
          CAERepOutput.xml
          cyclic_map.json
          exit.topo
          file*.dsub
          file*.ldhi
          file*.r0*
          file*.r1*
          file*.r2*
          file*.r3*
          file*.r4*
          file*.r5*
          file*.r6*
          file*.r7*
          file*.r8*
          file*.r9*
          file*.rd*
          file*.rst
          file.BCS
          file.ce
          file.cm
          file.cnd
          file.cnm
          file.DSP
          file.err
          file.gst
          file.json
          file.nd*
          file.nlh
          file.nr*
          file.PCS
          file.rdb
          file.rfl
          file.spm
          file0.BCS
          file0.ce
          file0.cnd
          file0.err
          file0.gst
          file0.nd*
          file0.nlh
          file0.nr*
          file0.PCS
          frequencies_*.out
          input.x17
          intermediate*.topo
          Mode_mapping_*.txt
          post.out
          record.txt
          solve*.out
          topo.err
          toput
          vars.topo
          SecDebugLog.txt
          sec.solverexitcode
          secStart.log
          sec.failure
      Reading exclude files...
          stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
          stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
          hosts.dat
          ClusterJobCustomization.xml
          ClusterJobs.py
          clusterjob_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.sh
          clusterjob_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.bat
          inquire.request
          inquire.confirm
          request.upload.rsm
          request.download.rsm
          wait.download.rsm
          scratch.job.rsm
          volatile.job.rsm
          restart.xml
          cancel_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
          liveLogLastPositions_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsm
          stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_kill.rsmout
          stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_kill.rsmout
          sec.interrupt
          stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_*.rsmout
          stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_*.rsmout
          stdout_task_*.live
          stderr_task_*.live
          control_task_*.rsm
          stdout_task_*.rsmout
          stderr_task_*.rsmout
          exitcode_task_*.rsmout
          exitcodeCommands_task_*.rsmout
          file.abt
      Reading environment variables...
          RSM_IRON_PYTHON_HOME = C:Program FilesANSYS Incv195commonfilesIronPython
          RSM_TASK_WORKING_DIRECTORY = C:RSMStagingaokqqj0p.5k1
          RSM_QUEUE_NAME = default
          RSM_CONFIGUREDQUEUE_NAME = Default
          RSM_COMPUTE_SERVER_MACHINE_NAME = Maincad
          RSM_HPC_JOBNAME = Mechanical
          RSM_HPC_DISPLAYNAME = Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
          RSM_HPC_CORES = 12
          RSM_HPC_DISTRIBUTED = TRUE
          RSM_HPC_NODE_EXCLUSIVE = FALSE
          RSM_HPC_QUEUE = default
          RSM_HPC_USER = MAINCADUser
          RSM_HPC_WORKDIR = C:RSMStagingaokqqj0p.5k1
          RSM_HPC_JOBTYPE = Mechanical_ANSYS
          RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY = C:Program FilesANSYS Incv195
          RSM_HPC_VERSION = 195
          RSM_HPC_STAGING = C:RSMStagingaokqqj0p.5k1
          RSM_HPC_LOCAL_PLATFORM = Windows
          RSM_HPC_CLUSTER_TARGET_PLATFORM = Windows
          RSM_HPC_STDOUTFILE = stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
          RSM_HPC_STDERRFILE = stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
          RSM_HPC_STDOUTLIVE = stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
          RSM_HPC_STDERRLIVE = stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
          RSM_HPC_SCRIPTS_DIRECTORY_LOCAL = C:Program FilesANSYS Incv195RSMConfigscripts
          RSM_HPC_SCRIPTS_DIRECTORY = C:Program FilesANSYS Incv195RSMConfigscripts
          RSM_HPC_SUBMITHOST = localhost
          RSM_HPC_STORAGEID =     a7ab7b67-dc3d-44cb-a665-813ffa216eee    Mechanical=LocalOS#localhost$C:RSMStagingaokqqj0p.5k1    Tuesday, October 08, 2019 10:40:05.011 AM    True
          RSM_HPC_PLATFORMSTORAGEID = C:RSMStagingaokqqj0p.5k1
          RSM_HPC_NATIVEOPTIONS =
          ARC_ROOT = C:Program FilesANSYS Incv195RSMConfigscripts....ARC
          RSM_HPC_KEYWORD = ARC
          RSM_PYTHON_LOCALE = en-us
      Reading AWP_ROOT environment variable name ...
          AWP_ROOT environment variable name is: AWP_ROOT195
      Reading Low Disk Space Warning Limit ...
          Low disk space warning threshold set at: 2.0GiB
      Reading File identifier ...
          File identifier found as: 782e78b5-2c00-45fa-b7ac-6976aa49c2cf
      Done reading control file.
      RSM_AWP_ROOT_NAME = AWP_ROOT195
      AWP_ROOT195 install directory: C:Program FilesANSYS Incv195
      RSM_MACHINES = maincad:4:cluster01:4:cluster02:4
      Number of nodes assigned for current job = 3
      Machine list:
      Checking DisableUNCCheck ...
      Unable to read registry for HKEY_CURRENT_USERSoftwareMicrosoftCommand Processor
      Ignore verifying DisableUNCCheck, you may check it manually if not already done so.
      Current Directory: C:RSMStagingaokqqj0p.5k1
      Running Process
      Running Solver : C:Program FilesANSYS Incv195ansysbinwinx64ANSYS195.exe -b nolist -s noread -acc nvidia -na 1 -p ansys -mpi intelmpi -i remote.dat -o solve.out -dis -machines maincad:4:cluster01:4:cluster02:4 -dir "CRSMStaging/aokqqj0p.5k1"
       *** FATAL ***
        (specified working directory does not exist)
       *** NOTE ***
        USAGE: C:Program FilesANSYS Incv195ANSYSbinwinx64ANSYS.EXE
                           [-d device name] [-j job name]
                           [-b list|nolist] [-m scratch memory(mb)]
                           [-s read|noread] [-g] [-db database(mb)]
                           [-p product] [-l language]
                           [-dyn] [-np #] [-mfm]
                           [-dvt] [-dis] [-machines list]
                           [-i inputfile] [-o outputfile]
                           [-ser port] [-scport port]
                           [-scname couplingname] [-schost hostname]
                           [-smp] [-mpi intelmpi|ibmmpi|msmpi]
                           [-dir working_directory ]
       *** FATAL ***
       *** NOTE ***
                           [-acc nvidia] [-na #]
       *** FATAL ***
       *** NOTE ***
       *** FATAL ***
       *** NOTE ***
       *** FATAL ***
       *** NOTE ***
       *** FATAL ***
       *** NOTE ***
       *** FATAL ***
       *** NOTE ***
       *** FATAL ***
       *** NOTE ***
    • JakeC
      If you are trying to distribute across multiple machines your staging directory can't be a local drive "c:"
      You will need to share that directory and in the staging directory setting use the unc path to that shared directory eg:
      \maincadRSMStaging
      Please be sure to set the RSMStaging share security to be open to all users and machines.
      Thank you,
      Jake
    • kolyan007
      That shared folder exists on maincad and has full access to everyone.
      >If you are trying to distribute across multiple machines your staging directory can't be a local drive "c:" - Does it applies to Submit Host as well? I.e. on Submit host in RSM configuration do I need to use OS file transfer and put UNC path to shared folder \maincadRSMStaging? Like below:
      Remote solvers already using it.
    • kolyan007
      The localhost HPC Resource has been changed to use operating system file transfer to the cluster staging directory, as on the screenshot above, to use UNC folder: \maincadRSMStaging.
      Solve process has failed with the error message below:
      1
      11/10/2019 1:580 pm
      2
      11/10/2019 1:580 pm
      3
      11/10/2019 1:580 pm
      4
      11/10/2019 1:580 pm
      5
      11/10/2019 1:580 pm
      6
      11/10/2019 1:580 pm
         Client Directory: C:TestProject - Copy - Copy_ProjectScratchScr771B
      7
      11/10/2019 1:580 pm
      8
      11/10/2019 1:580 pm
      9
      11/10/2019 1:580 pm
      10
      11/10/2019 1:580 pm
      11
      11/10/2019 1:580 pm
         Cluster Type: ARC
      12
      11/10/2019 1:580 pm
      13
      11/10/2019 1:580 pm
      14
      11/10/2019 1:580 pm
         Staging Directory: \MainCADRSMStaging
      15
      11/10/2019 1:580 pm
      16
      11/10/2019 1:580 pm
      17
      11/10/2019 1:580 pm
         Platform: Windows
      18
      11/10/2019 1:580 pm
      19
      11/10/2019 1:580 pm
      20
      11/10/2019 1:580 pm
      21
      11/10/2019 1:580 pm
      22
      11/10/2019 1:580 pm
      23
      11/10/2019 1:580 pm
      24
      11/10/2019 1:580 pm
      25
      11/10/2019 1:580 pm
      26
      11/10/2019 1:580 pm
         Inquire Files:
      27
      11/10/2019 1:580 pm
      28
      11/10/2019 1:580 pm
      29
      11/10/2019 1:580 pm
      30
      11/10/2019 1:580 pm
      31
      11/10/2019 1:580 pm
      32
      11/10/2019 1:580 pm
      33
      11/10/2019 1:580 pm
      34
      11/10/2019 1:580 pm
      35
      11/10/2019 1:580 pm
      Created storage directory \MainCADRSMStaging4w4eooau.l0x
      36
      11/10/2019 1:580 pm
      Runtime Settings:
      37
      11/10/2019 1:580 pm
      38
      11/10/2019 1:580 pm
         Submit Time: Friday, 11 October 2019 1:58 pm
      39
      11/10/2019 1:580 pm
         Directory: \MainCADRSMStaging4w4eooau.l0x
      40
      11/10/2019 1:580 pm
      File Transfer Package: Upload to localhost:0
      41
      11/10/2019 1:580 pm
      42
      11/10/2019 1:580 pm
         Local Directory: C:TestProject - Copy - Copy_ProjectScratchScr771B
      43
      11/10/2019 1:580 pm
         Storage Path: \MainCADRSMStaging4w4eooau.l0x
      44
      11/10/2019 1:580 pm
         Storage Location:
      45
      11/10/2019 1:580 pm
         Files: [*.dat,file*.*,*.mac,thermal.build,commands.xml,SecInput.txt]
      46
      11/10/2019 1:580 pm
         Exclude: [-]
      47
      11/10/2019 1:580 pm
      Storage contents:
      48
      11/10/2019 1:580 pm
      Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr771Bds.dat
      49
      11/10/2019 1:580 pm
      Copying C:TestProject - Copy - Copy_ProjectScratchScr771Bds.dat to //MainCAD/RSMStaging/4w4eooau.l0x/ds.dat
      50
      11/10/2019 1:580 pm
             File size: 39897206 bytes,  transferred: 39897206 bytes.
      51
      11/10/2019 1:580 pm
      Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr771Bremote.dat
      52
      11/10/2019 1:580 pm
      Copying C:TestProject - Copy - Copy_ProjectScratchScr771Bremote.dat to //MainCAD/RSMStaging/4w4eooau.l0x/remote.dat
      53
      11/10/2019 1:580 pm
             File size: 179 bytes,  transferred: 179 bytes.
      54
      11/10/2019 1:580 pm
      Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr771Bcommands.xml
      55
      11/10/2019 1:580 pm
      Copying C:TestProject - Copy - Copy_ProjectScratchScr771Bcommands.xml to //MainCAD/RSMStaging/4w4eooau.l0x/commands.xml
      56
      11/10/2019 1:580 pm
             File size: 477 bytes,  transferred: 477 bytes.
      57
      11/10/2019 1:580 pm
      Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr771BSecInput.txt
      58
      11/10/2019 1:580 pm
      Copying C:TestProject - Copy - Copy_ProjectScratchScr771BSecInput.txt to //MainCAD/RSMStaging/4w4eooau.l0x/SecInput.txt
      59
      11/10/2019 1:580 pm
             File size: 899 bytes,  transferred: 899 bytes.
      60
      11/10/2019 1:580 pm
      Storage contents:
      61
      11/10/2019 1:580 pm
         ds.dat
      62
      11/10/2019 1:580 pm
         remote.dat
      63
      11/10/2019 1:580 pm
         commands.xml
      64
      11/10/2019 1:580 pm
         SecInput.txt
      65
      11/10/2019 1:580 pm
      39898.76 KB, .11 sec (364982.55 KB/sec)
      66
      11/10/2019 1:580 pm
      67
      11/10/2019 1:580 pm
      Commands from commands.xml file
      68
      11/10/2019 1:580 pm
      Behavior code: Ansys.Rsm.ClusterOperations.Behaviors.MechanicalAnsysBehaviors
      69
      11/10/2019 1:580 pm
      Loading Cluster Customization file C:Program FilesANSYS Incv195RSMConfigxmlClusterJobCustomization.xml.
      70
      11/10/2019 1:580 pm
      No customization found for cluster machineName Maincad, type ARC
      71
      11/10/2019 1:580 pm
      HPC Commands Files Used:
      72
      11/10/2019 1:580 pm
         hpc_commands_ARC.xml
      73
      11/10/2019 1:580 pm
      Environment variables:
      74
      11/10/2019 1:580 pm
      75
      11/10/2019 1:580 pm
         RSM_IRON_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesIronPython
      76
      11/10/2019 1:580 pm
         RSM_PYTHON_EXE=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe
      77
      11/10/2019 1:580 pm
         RSM_TASK_WORKING_DIRECTORY=\MainCADRSMStaging4w4eooau.l0x
      78
      11/10/2019 1:580 pm
         RSM_USE_SSH_LINUX=False
      79
      11/10/2019 1:580 pm
         RSM_QUEUE_NAME=default
      80
      11/10/2019 1:580 pm
         RSM_CONFIGUREDQUEUE_NAME=Default
      81
      11/10/2019 1:580 pm
         RSM_COMPUTE_SERVER_MACHINE_NAME=Maincad
      82
      11/10/2019 1:580 pm
      83
      11/10/2019 1:580 pm
         RSM_HPC_DISPLAYNAME=Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
      84
      11/10/2019 1:580 pm
         RSM_HPC_CORES=12
      85
      11/10/2019 1:580 pm
      86
      11/10/2019 1:580 pm
         RSM_HPC_NODE_EXCLUSIVE=FALSE
      87
      11/10/2019 1:580 pm
         RSM_HPC_QUEUE=default
      88
      11/10/2019 1:580 pm
         RSM_HPC_USER=MAINCADUser
      89
      11/10/2019 1:580 pm
         RSM_HPC_WORKDIR=\MainCADRSMStaging4w4eooau.l0x
      90
      11/10/2019 1:580 pm
         RSM_HPC_JOBTYPE=Mechanical_ANSYS
      91
      11/10/2019 1:580 pm
         RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=C:Program FilesANSYS Incv195
      92
      11/10/2019 1:580 pm
         RSM_HPC_VERSION=195
      93
      11/10/2019 1:580 pm
         RSM_HPC_STAGING=\MainCADRSMStaging4w4eooau.l0x
      94
      11/10/2019 1:580 pm
         RSM_HPC_LOCAL_PLATFORM=Windows
      95
      11/10/2019 1:580 pm
         RSM_HPC_CLUSTER_TARGET_PLATFORM=Windows
      96
      11/10/2019 1:580 pm
         RSM_HPC_STDOUTFILE=stdout_3a6b4620-8d29-4665-88a3-df770a04d30d.rsmout
      97
      11/10/2019 1:580 pm
         RSM_HPC_STDERRFILE=stderr_3a6b4620-8d29-4665-88a3-df770a04d30d.rsmout
      98
      11/10/2019 1:580 pm
         RSM_HPC_STDOUTLIVE=stdout_3a6b4620-8d29-4665-88a3-df770a04d30d.live
      99
      11/10/2019 1:580 pm
         RSM_HPC_STDERRLIVE=stderr_3a6b4620-8d29-4665-88a3-df770a04d30d.live
      100
      11/10/2019 1:580 pm
         RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=C:Program FilesANSYS Incv195RSMConfigscripts
      101
      11/10/2019 1:580 pm
         RSM_HPC_SCRIPTS_DIRECTORY=%AWP_ROOT195%RSMConfigscripts
      102
      11/10/2019 1:580 pm
         RSM_HPC_SUBMITHOST=localhost
      103
      11/10/2019 1:580 pm
         RSM_HPC_STORAGEID=    dc1790b9-6290-4019-9b18-38acc7465469    Mechanical=LocalOS#localhost$\MainCADRSMStaging4w4eooau.l0x    Friday, October 11, 2019 12:580.393 AM    True
      104
      11/10/2019 1:580 pm
         RSM_HPC_PLATFORMSTORAGEID=\MainCADRSMStaging4w4eooau.l0x
      105
      11/10/2019 1:580 pm
         RSM_HPC_NATIVEOPTIONS=
      106
      11/10/2019 1:580 pm
         ARC_ROOT=C:Program FilesANSYS Incv195RSMConfigscripts....ARC
      107
      11/10/2019 1:580 pm
         RSM_HPC_KEYWORD=ARC
      108
      11/10/2019 1:580 pm
      109
      11/10/2019 1:580 pm
      110
      11/10/2019 1:580 pm
      111
      11/10/2019 1:580 pm
      112
      11/10/2019 1:580 pm
      113
      11/10/2019 1:580 pm
      114
      11/10/2019 1:580 pm
      Running 1 commands
      115
      11/10/2019 1:580 pm
      Job working directory: \MainCADRSMStaging4w4eooau.l0x
      116
      11/10/2019 1:580 pm
      117
      11/10/2019 1:580 pm
      118
      11/10/2019 1:580 pm
      119
      11/10/2019 1:580 pm
      External cluster command: queryQueues
      120
      11/10/2019 1:580 pm
         Cluster command before expansion: %ARC_ROOT%binArcQueues.exe
      121
      11/10/2019 1:580 pm
         Final cluster command: C:Program FilesANSYS Incv195RSMConfigscripts....ARCbinArcQueues.exe
      122
      11/10/2019 1:580 pm
         Working directory : \MainCADRSMStaging4w4eooau.l0x
      123
      11/10/2019 1:580 pm
         Variables:
      124
      11/10/2019 1:580 pm
      125
      11/10/2019 1:580 pm
      126
      11/10/2019 1:580 pm
      127
      11/10/2019 1:580 pm
      128
      11/10/2019 1:580 pm
      129
      11/10/2019 1:580 pm
      130
      11/10/2019 1:580 pm
      131
      11/10/2019 1:580 pm
      132
      11/10/2019 1:580 pm
      133
      11/10/2019 1:580 pm
      134
      11/10/2019 1:580 pm
             RSM_HPC_CORES=12
      135
      11/10/2019 1:580 pm
      136
      11/10/2019 1:580 pm
      137
      11/10/2019 1:580 pm
      138
      11/10/2019 1:580 pm
      139
      11/10/2019 1:580 pm
      140
      11/10/2019 1:580 pm
      141
      11/10/2019 1:580 pm
      142
      11/10/2019 1:580 pm
             RSM_HPC_VERSION=195
      143
      11/10/2019 1:580 pm
      144
      11/10/2019 1:580 pm
      145
      11/10/2019 1:580 pm
      146
      11/10/2019 1:580 pm
      147
      11/10/2019 1:580 pm
      148
      11/10/2019 1:580 pm
      149
      11/10/2019 1:580 pm
      150
      11/10/2019 1:580 pm
      151
      11/10/2019 1:580 pm
      152
      11/10/2019 1:580 pm
      153
      11/10/2019 1:580 pm
      154
      11/10/2019 1:580 pm
      155
      11/10/2019 1:580 pm
      156
      11/10/2019 1:580 pm
      157
      11/10/2019 1:580 pm
             RSM_HPC_KEYWORD=ARC
      158
      11/10/2019 1:580 pm
             RSM_HPC_PARSE_MARKER=START
      159
      11/10/2019 1:580 pm
      160
      11/10/2019 1:581 pm
      ArcMaster process running as NT AUTHORITYSYSTEM
      161
      11/10/2019 1:581 pm
      ArcNode process running as NT AUTHORITYSYSTEM
      162
      11/10/2019 1:581 pm
      Skipping autostart because Master processes is started as a service.
      163
      11/10/2019 1:581 pm
              Name            Status     Priority   Start Time    End Time   Max Jobs      Allowed Machines         Allowed Users
      164
      11/10/2019 1:581 pm
      165
      11/10/2019 1:581 pm
            default           Active        0        00:00:00     23:59:59      *     maincad:cluster01:clust...         all
      166
      11/10/2019 1:581 pm
             local            Active        0        00:00:00     23:59:59      *              maincad                   all
      167
      11/10/2019 1:581 pm
         * Indicates that resources have not been set up.  Any resource request will be accepted.
      168
      11/10/2019 1:581 pm
      External cluster command: checkQueueExists
      169
      11/10/2019 1:581 pm
         Cluster command before expansion: %RSM_PYTHON_EXE% -B -E "%RSM_HPC_SCRIPTS_DIRECTORY_LOCAL%/arcParsing.py" -queues %RSM_HPC_PARSE_MARKER%
      170
      11/10/2019 1:581 pm
         Final cluster command: C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe -B -E "C:Program FilesANSYS Incv195RSMConfigscripts/arcParsing.py" -queues START
      171
      11/10/2019 1:581 pm
      172
      11/10/2019 1:581 pm
         Variables:
      173
      11/10/2019 1:581 pm
      174
      11/10/2019 1:581 pm
      175
      11/10/2019 1:581 pm
      176
      11/10/2019 1:581 pm
      177
      11/10/2019 1:581 pm
      178
      11/10/2019 1:581 pm
      179
      11/10/2019 1:581 pm
      180
      11/10/2019 1:581 pm
      181
      11/10/2019 1:581 pm
      182
      11/10/2019 1:581 pm
      183
      11/10/2019 1:581 pm
             RSM_HPC_CORES=12
      184
      11/10/2019 1:581 pm
      185
      11/10/2019 1:581 pm
      186
      11/10/2019 1:581 pm
      187
      11/10/2019 1:581 pm
      188
      11/10/2019 1:581 pm
      189
      11/10/2019 1:581 pm
      190
      11/10/2019 1:581 pm
      191
      11/10/2019 1:581 pm
             RSM_HPC_VERSION=195
      192
      11/10/2019 1:581 pm
      193
      11/10/2019 1:581 pm
      194
      11/10/2019 1:581 pm
      195
      11/10/2019 1:581 pm
      196
      11/10/2019 1:581 pm
      197
      11/10/2019 1:581 pm
      198
      11/10/2019 1:581 pm
      199
      11/10/2019 1:581 pm
      200
      11/10/2019 1:581 pm
      201
      11/10/2019 1:581 pm
      202
      11/10/2019 1:581 pm
      203
      11/10/2019 1:581 pm
      204
      11/10/2019 1:581 pm
      205
      11/10/2019 1:581 pm
      206
      11/10/2019 1:581 pm
             RSM_HPC_KEYWORD=ARC
      207
      11/10/2019 1:581 pm
      208
      11/10/2019 1:581 pm
             RSM_HPC_PRIMARY_STDOUT=ArcMaster process running as NT AUTHORITYSYSTEM
      209
      11/10/2019 1:581 pm
      210
      11/10/2019 1:581 pm
      211
      11/10/2019 1:581 pm
      212
      11/10/2019 1:581 pm
      213
      11/10/2019 1:581 pm
      214
      11/10/2019 1:581 pm
      215
      11/10/2019 1:581 pm
      216
      11/10/2019 1:581 pm
             RSM_HPC_PRIMARY_STDERR=
      217
      11/10/2019 1:581 pm
      218
      11/10/2019 1:581 pm
      Executing command: %AWP_ROOT195%SECSolverExecutionControllerrunsec.bat   (Ansys Solver)
      219
      11/10/2019 1:581 pm
      commands.xml file: \MainCADRSMStaging4w4eooau.l0xcommands.xml
      220
      11/10/2019 1:581 pm
      221
      11/10/2019 1:581 pm
      222
      11/10/2019 1:581 pm
      223
      11/10/2019 1:581 pm
           true
      224
      11/10/2019 1:581 pm
      225
      11/10/2019 1:581 pm
           12
      226
      11/10/2019 1:581 pm
      227
      11/10/2019 1:581 pm
      228
      11/10/2019 1:58
      JakeC
      For this log it appears as though running CMD from a UNC path is blocked.
      To unblock it please do the following on each machine:
      Start a registry editor (e.g., regedit.exe).
      Navigate to theHKEY_LOCAL_MACHINESOFTWAREMicrosoftCommand Processor registry subkey.
      From the Edit menu, select New, DWORD Value; enter the name DisableUNCCheck; then press Enter.
      Double-click the new value, set it to 1, then click OK.
      Close the registry editor.
      Reboot the machine
      Thank you,
      Jake
    • kolyan007
      Thank you Jake. The UNC has been disabled on all machines using steps above.
      See below my RSM configuration settings for localhost on Submit Host and most recent error log. Please advise what else is wrong in my configuration.
      1     13/10/2019 12:01:15 am     RSM Version: 19.5.420.0, Build Date: 30/07/2019 57:06 am
      2     13/10/2019 12:01:15 am     RSM File Version: 19.5.0-beta.3+Branch.release-19.5.Sha.9c15e0a3e0a608e8efe8c568e494d2160788d025
      3     13/10/2019 12:01:15 am     RSM Library Version: 19.5.0.0
      4     13/10/2019 12:01:15 am     Job Name: Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
      5     13/10/2019 12:01:15 am        Type: Mechanical_ANSYS
      6     13/10/2019 12:01:15 am        Client Directory: C:TestProject - Copy - Copy_ProjectScratchScr1E08
      7     13/10/2019 12:01:15 am        Client Machine: Maincad
      8     13/10/2019 12:01:15 am        Queue: Default [localhost, default]
      9     13/10/2019 12:01:15 am        Template: Mechanical_ANSYSJob.xml
      10     13/10/2019 12:01:15 am     Cluster Configuration: localhost [localhost]
      11     13/10/2019 12:01:15 am        Cluster Type: ARC
      12     13/10/2019 12:01:15 am        Custom Keyword: blank
      13     13/10/2019 12:01:15 am        Transfer Option: NativeOS
      14     13/10/2019 12:01:15 am        Staging Directory: \MainCADRSMStaging
      15     13/10/2019 12:01:15 am        Delete Staging Directory: True
      16     13/10/2019 12:01:15 am        Local Scratch Directory: blank
      17     13/10/2019 12:01:15 am        Platform: Windows
      18     13/10/2019 12:01:15 am        Cluster Submit Options: blank
      19     13/10/2019 12:01:15 am        Normal Inputs: [*.dat,file*.*,*.mac,thermal.build,commands.xml,SecInput.txt]
      20     13/10/2019 12:01:15 am        Cancel Inputs: [file.abt,sec.interrupt]
      21     13/10/2019 12:01:15 am        Excluded Inputs: [-]
      22     13/10/2019 12:01:15 am        Normal Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,secStart.log,sec.validation.executed,sec.envvarvalidation.executed,sec.failure]
      23     13/10/2019 12:01:15 am        Failure Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,sec.solverexitcode,secStart.log,sec.failure,sec.envvarvalidation.executed]
      24     13/10/2019 12:01:15 am        Cancel Outputs: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
      25     13/10/2019 12:01:15 am        Excluded Outputs: [-]
      26     13/10/2019 12:01:15 am        Inquire Files:
      27     13/10/2019 12:01:15 am          normal: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,secStart.log,sec.validation.executed,sec.envvarvalidation.executed,sec.failure]
      28     13/10/2019 12:01:15 am          cancel: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
      29     13/10/2019 12:01:15 am          failure: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,sec.solverexitcode,secStart.log,sec.failure,sec.envvarvalidation.executed]
      30     13/10/2019 12:01:15 am          RemotePostInformation: [RemotePostInformation.txt]
      31     13/10/2019 12:01:15 am          SolutionInformation: [solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
      32     13/10/2019 12:01:15 am          PostDuringSolve: [file.rcn,file.redm,file.rfl,file.rfrq,file.rmg,file.rdsp,file.rsx,file.rst,file.rth,solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
      33     13/10/2019 12:01:15 am          transcript: [solve.out,monitor.json]
      34     13/10/2019 12:01:15 am     Submission in progress...
      35     13/10/2019 12:01:15 am     Created storage directory \MainCADRSMStagingeubgp21n.ezb
      36     13/10/2019 12:01:15 am     Runtime Settings:
      37     13/10/2019 12:01:15 am        Job Owner: MAINCADUser
      38     13/10/2019 12:01:15 am        Submit Time: Sunday, 13 October 2019 12:01 am
      39     13/10/2019 12:01:15 am        Directory: \MainCADRSMStagingeubgp21n.ezb
      40     13/10/2019 12:01:15 am     File Transfer Package: Upload to localhost:0
      41     13/10/2019 12:01:15 am        Name: RSM_Upload_During_Submit
      42     13/10/2019 12:01:15 am        Local Directory: C:TestProject - Copy - Copy_ProjectScratchScr1E08
      43     13/10/2019 12:01:15 am        Storage Path: \MainCADRSMStagingeubgp21n.ezb
      44     13/10/2019 12:01:15 am        Storage Location:
      45     13/10/2019 12:01:15 am        Files: [*.dat,file*.*,*.mac,thermal.build,commands.xml,SecInput.txt]
      46     13/10/2019 12:01:15 am        Exclude: [-]
      47     13/10/2019 12:01:15 am     Storage contents:
      48     13/10/2019 12:01:15 am     Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr1E08ds.dat
      49     13/10/2019 12:01:15 am     Copying C:TestProject - Copy - Copy_ProjectScratchScr1E08ds.dat to //MainCAD/RSMStaging/eubgp21n.ezb/ds.dat
      50     13/10/2019 12:01:15 am            File size: 39897206 bytes,  transferred: 39897206 bytes.
      51     13/10/2019 12:01:15 am     Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr1E08remote.dat
      52     13/10/2019 12:01:15 am     Copying C:TestProject - Copy - Copy_ProjectScratchScr1E08remote.dat to //MainCAD/RSMStaging/eubgp21n.ezb/remote.dat
      53     13/10/2019 12:01:15 am            File size: 179 bytes,  transferred: 179 bytes.
      54     13/10/2019 12:01:15 am     Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr1E08commands.xml
      55     13/10/2019 12:01:15 am     Copying C:TestProject - Copy - Copy_ProjectScratchScr1E08commands.xml to //MainCAD/RSMStaging/eubgp21n.ezb/commands.xml
      56     13/10/2019 12:01:15 am            File size: 477 bytes,  transferred: 477 bytes.
      57     13/10/2019 12:01:15 am     Uploading file: C:TestProject - Copy - Copy_ProjectScratchScr1E08SecInput.txt
      58     13/10/2019 12:01:15 am     Copying C:TestProject - Copy - Copy_ProjectScratchScr1E08SecInput.txt to //MainCAD/RSMStaging/eubgp21n.ezb/SecInput.txt
      59     13/10/2019 12:01:15 am            File size: 899 bytes,  transferred: 899 bytes.
      60     13/10/2019 12:01:15 am     Storage contents:
      61     13/10/2019 12:01:15 am        ds.dat
      62     13/10/2019 12:01:15 am        remote.dat
      63     13/10/2019 12:01:15 am        commands.xml
      64     13/10/2019 12:01:15 am        SecInput.txt
      65     13/10/2019 12:01:15 am     39898.76 KB, .11 sec (364870.74 KB/sec)
      66     13/10/2019 12:01:15 am     Submission in progress...
      67     13/10/2019 12:01:15 am     Commands from commands.xml file
      68     13/10/2019 12:01:15 am     Behavior code: Ansys.Rsm.ClusterOperations.Behaviors.MechanicalAnsysBehaviors
      69     13/10/2019 12:01:15 am     Loading Cluster Customization file C:Program FilesANSYS Incv195RSMConfigxmlClusterJobCustomization.xml.
      70     13/10/2019 12:01:15 am     No customization found for cluster machineName Maincad, type ARC
      71     13/10/2019 12:01:15 am     HPC Commands Files Used:
      72     13/10/2019 12:01:15 am        hpc_commands_ARC.xml
      73     13/10/2019 12:01:15 am     Environment variables:
      74     13/10/2019 12:01:15 am        RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
      75     13/10/2019 12:01:15 am        RSM_IRON_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesIronPython
      76     13/10/2019 12:01:15 am        RSM_PYTHON_EXE=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe
      77     13/10/2019 12:01:15 am        RSM_TASK_WORKING_DIRECTORY=\MainCADRSMStagingeubgp21n.ezb
      78     13/10/2019 12:01:15 am        RSM_USE_SSH_LINUX=False
      79     13/10/2019 12:01:15 am        RSM_QUEUE_NAME=default
      80     13/10/2019 12:01:15 am        RSM_CONFIGUREDQUEUE_NAME=Default
      81     13/10/2019 12:01:15 am        RSM_COMPUTE_SERVER_MACHINE_NAME=Maincad
      82     13/10/2019 12:01:15 am        RSM_HPC_JOBNAME=Mechanical
      83     13/10/2019 12:01:15 am        RSM_HPC_DISPLAYNAME=Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
      84     13/10/2019 12:01:15 am        RSM_HPC_CORES=12
      85     13/10/2019 12:01:15 am        RSM_HPC_DISTRIBUTED=TRUE
      86     13/10/2019 12:01:15 am        RSM_HPC_NODE_EXCLUSIVE=FALSE
      87     13/10/2019 12:01:15 am        RSM_HPC_QUEUE=default
      88     13/10/2019 12:01:15 am        RSM_HPC_USER=MAINCADUser
      89     13/10/2019 12:01:15 am        RSM_HPC_WORKDIR=\MainCADRSMStagingeubgp21n.ezb
      90     13/10/2019 12:01:15 am        RSM_HPC_JOBTYPE=Mechanical_ANSYS
      91     13/10/2019 12:01:15 am        RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=C:Program FilesANSYS Incv195
      92     13/10/2019 12:01:15 am        RSM_HPC_VERSION=195
      93     13/10/2019 12:01:15 am        RSM_HPC_STAGING=\MainCADRSMStagingeubgp21n.ezb
      94     13/10/2019 12:01:15 am        RSM_HPC_LOCAL_PLATFORM=Windows
      95     13/10/2019 12:01:15 am        RSM_HPC_CLUSTER_TARGET_PLATFORM=Windows
      96     13/10/2019 12:01:15 am        RSM_HPC_STDOUTFILE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      97     13/10/2019 12:01:15 am        RSM_HPC_STDERRFILE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      98     13/10/2019 12:01:15 am        RSM_HPC_STDOUTLIVE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      99     13/10/2019 12:01:15 am        RSM_HPC_STDERRLIVE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      100     13/10/2019 12:01:15 am        RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=C:Program FilesANSYS Incv195RSMConfigscripts
      101     13/10/2019 12:01:15 am        RSM_HPC_SCRIPTS_DIRECTORY=%AWP_ROOT195%RSMConfigscripts
      102     13/10/2019 12:01:15 am        RSM_HPC_SUBMITHOST=localhost
      103     13/10/2019 12:01:15 am        RSM_HPC_STORAGEID=    2e240152-9c98-4c8b-b806-5ccbbda6db14    Mechanical=LocalOS#localhost$\MainCADRSMStagingeubgp21n.ezb    Saturday, October 12, 2019 11:01:15.288 AM    True
      104     13/10/2019 12:01:15 am        RSM_HPC_PLATFORMSTORAGEID=\MainCADRSMStagingeubgp21n.ezb
      105     13/10/2019 12:01:15 am        RSM_HPC_NATIVEOPTIONS=
      106     13/10/2019 12:01:15 am        ARC_ROOT=C:Program FilesANSYS Incv195RSMConfigscripts....ARC
      107     13/10/2019 12:01:15 am        RSM_HPC_KEYWORD=ARC
      108     13/10/2019 12:01:15 am     JobType is: Mechanical_ANSYS
      109     13/10/2019 12:01:15 am     Final command platform: Windows
      110     13/10/2019 12:01:15 am     RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
      111     13/10/2019 12:01:15 am     RSM_HPC_JOBNAME=Mechanical
      112     13/10/2019 12:01:15 am     Distributed mode requested: True
      113     13/10/2019 12:01:15 am     RSM_HPC_DISTRIBUTED=TRUE
      114     13/10/2019 12:01:15 am     Running 1 commands
      115     13/10/2019 12:01:15 am     Job working directory: \MainCADRSMStagingeubgp21n.ezb
      116     13/10/2019 12:01:15 am     Number of CPU requested: 12
      117     13/10/2019 12:01:15 am     AWP_ROOT195=C:Program FilesANSYS Incv195
      118     13/10/2019 12:01:15 am     Checking queue default exists ...
      119     13/10/2019 12:01:15 am     External cluster command: queryQueues
      120     13/10/2019 12:01:15 am        Cluster command before expansion: %ARC_ROOT%binArcQueues.exe
      121     13/10/2019 12:01:15 am        Final cluster command: C:Program FilesANSYS Incv195RSMConfigscripts....ARCbinArcQueues.exe
      122     13/10/2019 12:01:15 am        Working directory : \MainCADRSMStagingeubgp21n.ezb
      123     13/10/2019 12:01:15 am        Variables:
      124     13/10/2019 12:01:15 am            RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
      125     13/10/2019 12:01:15 am            RSM_IRON_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesIronPython
      126     13/10/2019 12:01:15 am            RSM_PYTHON_EXE=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe
      127     13/10/2019 12:01:15 am            RSM_TASK_WORKING_DIRECTORY=\MainCADRSMStagingeubgp21n.ezb
      128     13/10/2019 12:01:15 am            RSM_USE_SSH_LINUX=False
      129     13/10/2019 12:01:15 am            RSM_QUEUE_NAME=default
      130     13/10/2019 12:01:15 am            RSM_CONFIGUREDQUEUE_NAME=Default
      131     13/10/2019 12:01:15 am            RSM_COMPUTE_SERVER_MACHINE_NAME=Maincad
      132     13/10/2019 12:01:15 am            RSM_HPC_JOBNAME=Mechanical
      133     13/10/2019 12:01:15 am            RSM_HPC_DISPLAYNAME=Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
      134     13/10/2019 12:01:15 am            RSM_HPC_CORES=12
      135     13/10/2019 12:01:15 am            RSM_HPC_DISTRIBUTED=TRUE
      136     13/10/2019 12:01:15 am            RSM_HPC_NODE_EXCLUSIVE=FALSE
      137     13/10/2019 12:01:15 am            RSM_HPC_QUEUE=default
      138     13/10/2019 12:01:15 am            RSM_HPC_USER=MAINCADUser
      139     13/10/2019 12:01:15 am            RSM_HPC_WORKDIR=\MainCADRSMStagingeubgp21n.ezb
      140     13/10/2019 12:01:15 am            RSM_HPC_JOBTYPE=Mechanical_ANSYS
      141     13/10/2019 12:01:15 am            RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=C:Program FilesANSYS Incv195
      142     13/10/2019 12:01:15 am            RSM_HPC_VERSION=195
      143     13/10/2019 12:01:15 am            RSM_HPC_STAGING=\MainCADRSMStagingeubgp21n.ezb
      144     13/10/2019 12:01:15 am            RSM_HPC_LOCAL_PLATFORM=Windows
      145     13/10/2019 12:01:15 am            RSM_HPC_CLUSTER_TARGET_PLATFORM=Windows
      146     13/10/2019 12:01:15 am            RSM_HPC_STDOUTFILE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      147     13/10/2019 12:01:15 am            RSM_HPC_STDERRFILE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      148     13/10/2019 12:01:15 am            RSM_HPC_STDOUTLIVE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      149     13/10/2019 12:01:15 am            RSM_HPC_STDERRLIVE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      150     13/10/2019 12:01:15 am            RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=C:Program FilesANSYS Incv195RSMConfigscripts
      151     13/10/2019 12:01:15 am            RSM_HPC_SCRIPTS_DIRECTORY=%AWP_ROOT195%RSMConfigscripts
      152     13/10/2019 12:01:15 am            RSM_HPC_SUBMITHOST=localhost
      153     13/10/2019 12:01:15 am            RSM_HPC_STORAGEID=    2e240152-9c98-4c8b-b806-5ccbbda6db14    Mechanical=LocalOS#localhost$\MainCADRSMStagingeubgp21n.ezb    Saturday, October 12, 2019 11:01:15.288 AM    True
      154     13/10/2019 12:01:15 am            RSM_HPC_PLATFORMSTORAGEID=\MainCADRSMStagingeubgp21n.ezb
      155     13/10/2019 12:01:15 am            RSM_HPC_NATIVEOPTIONS=
      156     13/10/2019 12:01:15 am            ARC_ROOT=C:Program FilesANSYS Incv195RSMConfigscripts....ARC
      157     13/10/2019 12:01:15 am            RSM_HPC_KEYWORD=ARC
      158     13/10/2019 12:01:15 am            RSM_HPC_PARSE_MARKER=START
      159     13/10/2019 12:01:15 am
      160     13/10/2019 12:01:16 am     ArcMaster process running as NT AUTHORITYSYSTEM
      161     13/10/2019 12:01:16 am     ArcNode process running as NT AUTHORITYSYSTEM
      162     13/10/2019 12:01:16 am     Skipping autostart because Master processes is started as a service.
      163     13/10/2019 12:01:16 am             Name            Status     Priority   Start Time    End Time   Max Jobs      Allowed Machines         Allowed Users
      164     13/10/2019 12:01:16 am     ================================================================================================================================
      165     13/10/2019 12:01:16 am           default           Active        0        00:00:00     23:59:59      *     maincad:cluster01:clust...         all
      166     13/10/2019 12:01:16 am            local            Active        0        00:00:00     23:59:59      *              maincad                   all
      167     13/10/2019 12:01:16 am        * Indicates that resources have not been set up.  Any resource request will be accepted.
      168     13/10/2019 12:01:16 am     External cluster command: checkQueueExists
      169     13/10/2019 12:01:16 am        Cluster command before expansion: %RSM_PYTHON_EXE% -B -E "%RSM_HPC_SCRIPTS_DIRECTORY_LOCAL%/arcParsing.py" -queues %RSM_HPC_PARSE_MARKER%
      170     13/10/2019 12:01:16 am        Final cluster command: C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe -B -E "C:Program FilesANSYS Incv195RSMConfigscripts/arcParsing.py" -queues START
      171     13/10/2019 12:01:16 am        Working directory : \MainCADRSMStagingeubgp21n.ezb
      172     13/10/2019 12:01:16 am        Variables:
      173     13/10/2019 12:01:16 am            RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
      174     13/10/2019 12:01:16 am            RSM_IRON_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesIronPython
      175     13/10/2019 12:01:16 am            RSM_PYTHON_EXE=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe
      176     13/10/2019 12:01:16 am            RSM_TASK_WORKING_DIRECTORY=\MainCADRSMStagingeubgp21n.ezb
      177     13/10/2019 12:01:16 am            RSM_USE_SSH_LINUX=False
      178     13/10/2019 12:01:16 am            RSM_QUEUE_NAME=default
      179     13/10/2019 12:01:16 am            RSM_CONFIGUREDQUEUE_NAME=Default
      180     13/10/2019 12:01:16 am            RSM_COMPUTE_SERVER_MACHINE_NAME=Maincad
      181     13/10/2019 12:01:16 am            RSM_HPC_JOBNAME=Mechanical
      182     13/10/2019 12:01:16 am            RSM_HPC_DISPLAYNAME=Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
      183     13/10/2019 12:01:16 am            RSM_HPC_CORES=12
      184     13/10/2019 12:01:16 am            RSM_HPC_DISTRIBUTED=TRUE
      185     13/10/2019 12:01:16 am            RSM_HPC_NODE_EXCLUSIVE=FALSE
      186     13/10/2019 12:01:16 am            RSM_HPC_QUEUE=default
      187     13/10/2019 12:01:16 am            RSM_HPC_USER=MAINCADUser
      188     13/10/2019 12:01:16 am            RSM_HPC_WORKDIR=\MainCADRSMStagingeubgp21n.ezb
      189     13/10/2019 12:01:16 am            RSM_HPC_JOBTYPE=Mechanical_ANSYS
      190     13/10/2019 12:01:16 am            RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=C:Program FilesANSYS Incv195
      191     13/10/2019 12:01:16 am            RSM_HPC_VERSION=195
      192     13/10/2019 12:01:16 am            RSM_HPC_STAGING=\MainCADRSMStagingeubgp21n.ezb
      193     13/10/2019 12:01:16 am            RSM_HPC_LOCAL_PLATFORM=Windows
      194     13/10/2019 12:01:16 am            RSM_HPC_CLUSTER_TARGET_PLATFORM=Windows
      195     13/10/2019 12:01:16 am            RSM_HPC_STDOUTFILE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      196     13/10/2019 12:01:16 am            RSM_HPC_STDERRFILE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      197     13/10/2019 12:01:16 am            RSM_HPC_STDOUTLIVE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      198     13/10/2019 12:01:16 am            RSM_HPC_STDERRLIVE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      199     13/10/2019 12:01:16 am            RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=C:Program FilesANSYS Incv195RSMConfigscripts
      200     13/10/2019 12:01:16 am            RSM_HPC_SCRIPTS_DIRECTORY=%AWP_ROOT195%RSMConfigscripts
      201     13/10/2019 12:01:16 am            RSM_HPC_SUBMITHOST=localhost
      202     13/10/2019 12:01:16 am            RSM_HPC_STORAGEID=    2e240152-9c98-4c8b-b806-5ccbbda6db14    Mechanical=LocalOS#localhost$\MainCADRSMStagingeubgp21n.ezb    Saturday, October 12, 2019 11:01:15.288 AM    True
      203     13/10/2019 12:01:16 am            RSM_HPC_PLATFORMSTORAGEID=\MainCADRSMStagingeubgp21n.ezb
      204     13/10/2019 12:01:16 am            RSM_HPC_NATIVEOPTIONS=
      205     13/10/2019 12:01:16 am            ARC_ROOT=C:Program FilesANSYS Incv195RSMConfigscripts....ARC
      206     13/10/2019 12:01:16 am            RSM_HPC_KEYWORD=ARC
      207     13/10/2019 12:01:16 am            RSM_HPC_PARSE_MARKER=START
      208     13/10/2019 12:01:16 am            RSM_HPC_PRIMARY_STDOUT=ArcMaster process running as NT AUTHORITYSYSTEM
      209     13/10/2019 12:01:16 am     ArcNode process running as NT AUTHORITYSYSTEM
      210     13/10/2019 12:01:16 am     Skipping autostart because Master processes is started as a service.
      211     13/10/2019 12:01:16 am             Name            Status     Priority   Start Time    End Time   Max Jobs      Allowed Machines         Allowed Users
      212     13/10/2019 12:01:16 am     ================================================================================================================================
      213     13/10/2019 12:01:16 am           default           Active        0        00:00:00     23:59:59      *     maincad:cluster01:clust...         all
      214     13/10/2019 12:01:16 am            local            Active        0        00:00:00     23:59:59      *              maincad                   all
      215     13/10/2019 12:01:16 am        * Indicates that resources have not been set up.  Any resource request will be accepted.
      216     13/10/2019 12:01:16 am            RSM_HPC_PRIMARY_STDERR=
      217     13/10/2019 12:01:16 am
      218     13/10/2019 12:01:17 am     Executing command: %AWP_ROOT195%SECSolverExecutionControllerrunsec.bat   (Ansys Solver)
      219     13/10/2019 12:01:17 am
      commands.xml file: \MainCADRSMStagingeubgp21n.ezbcommands.xml
      220     13/10/2019 12:01:17 am
      221     13/10/2019 12:01:17 am
      222     13/10/2019 12:01:17 am
      223     13/10/2019 12:01:17 am          true
      224     13/10/2019 12:01:17 am
      225     13/10/2019 12:01:17 am          12
      226     13/10/2019 12:01:17 am
      227     13/10/2019 12:01:17 am
      228     13/10/2019 12:01:17 am
      229     13/10/2019 12:01:17 am
      230     13/10/2019 12:01:17 am
      231     13/10/2019 12:01:17 am              %AWP_ROOT195%SECSolverExecutionControllerrunsec.bat
      232     13/10/2019 12:01:17 am              %AWP_ROOT195%/SEC/SolverExecutionController/runsec.sh
      233     13/10/2019 12:01:17 am
      234     13/10/2019 12:01:17 am
      235     13/10/2019 12:01:17 am
      236     13/10/2019 12:01:17 am
      237     13/10/2019 12:01:17 am
      238     13/10/2019 12:01:17 am
      commands.xml file END
      239     13/10/2019 12:01:17 am
      SecInput.txt file: \MainCADRSMStagingeubgp21n.ezbSecInput.txt
      240     13/10/2019 12:01:17 am        #begin
      241     13/10/2019 12:01:17 am        Modifier
      242     13/10/2019 12:01:17 am        SolverTag
      243     13/10/2019 12:01:17 am        Ansys
      244     13/10/2019 12:01:17 am        #end
      245     13/10/2019 12:01:17 am
      246     13/10/2019 12:01:17 am        #begin
      247     13/10/2019 12:01:17 am        Modifier
      248     13/10/2019 12:01:17 am        OperationMode
      249     13/10/2019 12:01:17 am        Normal
      250     13/10/2019 12:01:17 am        #end
      251     13/10/2019 12:01:17 am
      252     13/10/2019 12:01:17 am        #begin
      253     13/10/2019 12:01:17 am        InputData
      254     13/10/2019 12:01:17 am        ProductVersion
      255     13/10/2019 12:01:17 am        195
      256     13/10/2019 12:01:17 am        #end
      257     13/10/2019 12:01:17 am
      258     13/10/2019 12:01:17 am        #begin
      259     13/10/2019 12:01:17 am        Modifier
      260     13/10/2019 12:01:17 am        EnableApplicationBootstrapping
      261     13/10/2019 12:01:17 am        True
      262     13/10/2019 12:01:17 am        #end
      263     13/10/2019 12:01:17 am
      264     13/10/2019 12:01:17 am        #begin
      265     13/10/2019 12:01:17 am        InputData
      266     13/10/2019 12:01:17 am        SelectivePluginList
      267     13/10/2019 12:01:17 am        #list
      268     13/10/2019 12:01:17 am        plugins.ansys
      269     13/10/2019 12:01:17 am        plugins.common
      270     13/10/2019 12:01:17 am        plugins.ekm
      271     13/10/2019 12:01:17 am        bootstrap.ansys
      272     13/10/2019 12:01:17 am        bootstrap.rsm
      273     13/10/2019 12:01:17 am        bootstrap.common
      274     13/10/2019 12:01:17 am        bootstrap.ekm
      275     13/10/2019 12:01:17 am        #end
      276     13/10/2019 12:01:17 am
      277     13/10/2019 12:01:17 am        #begin
      278     13/10/2019 12:01:17 am        Modifier
      279     13/10/2019 12:01:17 am        EnableRsmBootstrapping
      280     13/10/2019 12:01:17 am        True
      281     13/10/2019 12:01:17 am        #end
      282     13/10/2019 12:01:17 am
      283     13/10/2019 12:01:17 am        #begin
      284     13/10/2019 12:01:17 am        InputData
      285     13/10/2019 12:01:17 am        AnsysJobName
      286     13/10/2019 12:01:17 am        file
      287     13/10/2019 12:01:17 am        #end
      288     13/10/2019 12:01:17 am
      289     13/10/2019 12:01:17 am        #begin
      290     13/10/2019 12:01:17 am        InputData
      291     13/10/2019 12:01:17 am        AnsysOutFileName
      292     13/10/2019 12:01:17 am        solve.out
      293     13/10/2019 12:01:17 am        #end
      294     13/10/2019 12:01:17 am
      295     13/10/2019 12:01:17 am        #begin
      296     13/10/2019 12:01:17 am        Modifier
      297     13/10/2019 12:01:17 am        CaptureSolverStdout
      298     13/10/2019 12:01:17 am        True
      299     13/10/2019 12:01:17 am        #end
      300     13/10/2019 12:01:17 am
      301     13/10/2019 12:01:17 am        #begin
      302     13/10/2019 12:01:17 am        Modifier
      303     13/10/2019 12:01:17 am        CaptureSolverStderr
      304     13/10/2019 12:01:17 am        True
      305     13/10/2019 12:01:17 am        #end
      306     13/10/2019 12:01:17 am
      307     13/10/2019 12:01:17 am        #begin
      308     13/10/2019 12:01:17 am        Modifier
      309     13/10/2019 12:01:17 am        Distributed
      310     13/10/2019 12:01:17 am        On
      311     13/10/2019 12:01:17 am        #end
      312     13/10/2019 12:01:17 am
      313     13/10/2019 12:01:17 am        #begin
      314     13/10/2019 12:01:17 am        Modifier
      315     13/10/2019 12:01:17 am        AnsysEnableSlaveNodeCopyBack
      316     13/10/2019 12:01:17 am        True
      317     13/10/2019 12:01:17 am        #end
      318     13/10/2019 12:01:17 am
      319     13/10/2019 12:01:17 am        #begin
      320     13/10/2019 12:01:17 am        InputData
      321     13/10/2019 12:01:17 am        NumberOfProcesses
      322     13/10/2019 12:01:17 am        12
      323     13/10/2019 12:01:17 am        #end
      324     13/10/2019 12:01:17 am
      325     13/10/2019 12:01:17 am        #begin
      326     13/10/2019 12:01:17 am        InputData
      327     13/10/2019 12:01:17 am        Arguments
      328     13/10/2019 12:01:17 am         -b nolist -s noread -p ansys -mpi intelmpi -i remote.dat -o solve.out
      329     13/10/2019 12:01:17 am        #end
      330     13/10/2019 12:01:17 am
      331     13/10/2019 12:01:17 am
      SecInput.txt file END
      332     13/10/2019 12:01:17 am     External cluster command: submit
      333     13/10/2019 12:01:17 am        Cluster command before expansion: %ARC_ROOT%binArcSubmit.exe -q "%RSM_HPC_QUEUE%" -a "%RSM_HPC_JOBNAME%" %RSM_HPC_NATIVEOPTIONS% -n %RSM_HPC_CORES% -w "%RSM_HPC_STAGING%" -o "%RSM_HPC_STAGING%/%RSM_HPC_STDOUTFILE%" -e "%RSM_HPC_STAGING%/%RSM_HPC_STDERRFILE%" "%RSM_HPC_COMMAND%"
      334     13/10/2019 12:01:17 am        Final cluster command: C:Program FilesANSYS Incv195RSMConfigscripts....ARCbinArcSubmit.exe -q "default" -a "Mechanical"  -n 12 -w "\MainCADRSMStagingeubgp21n.ezb" -o "\MainCADRSMStagingeubgp21n.ezb/stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout" -e "\MainCADRSMStagingeubgp21n.ezb/stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout" "clusterjob_9f9da426-822a-4234-a55a-2a8fc2bef7c8.bat"
      335     13/10/2019 12:01:17 am        Working directory : \MainCADRSMStagingeubgp21n.ezb
      336     13/10/2019 12:01:17 am        Variables:
      337     13/10/2019 12:01:17 am            RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
      338     13/10/2019 12:01:17 am            RSM_IRON_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesIronPython
      339     13/10/2019 12:01:17 am            RSM_PYTHON_EXE=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe
      340     13/10/2019 12:01:17 am            RSM_TASK_WORKING_DIRECTORY=\MainCADRSMStagingeubgp21n.ezb
      341     13/10/2019 12:01:17 am            RSM_USE_SSH_LINUX=False
      342     13/10/2019 12:01:17 am            RSM_QUEUE_NAME=default
      343     13/10/2019 12:01:17 am            RSM_CONFIGUREDQUEUE_NAME=Default
      344     13/10/2019 12:01:17 am            RSM_COMPUTE_SERVER_MACHINE_NAME=Maincad
      345     13/10/2019 12:01:17 am            RSM_HPC_JOBNAME=Mechanical
      346     13/10/2019 12:01:17 am            RSM_HPC_DISPLAYNAME=Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
      347     13/10/2019 12:01:17 am            RSM_HPC_CORES=12
      348     13/10/2019 12:01:17 am            RSM_HPC_DISTRIBUTED=TRUE
      349     13/10/2019 12:01:17 am            RSM_HPC_NODE_EXCLUSIVE=FALSE
      350     13/10/2019 12:01:17 am            RSM_HPC_QUEUE=default
      351     13/10/2019 12:01:17 am            RSM_HPC_USER=MAINCADUser
      352     13/10/2019 12:01:17 am            RSM_HPC_WORKDIR=\MainCADRSMStagingeubgp21n.ezb
      353     13/10/2019 12:01:17 am            RSM_HPC_JOBTYPE=Mechanical_ANSYS
      354     13/10/2019 12:01:17 am            RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=C:Program FilesANSYS Incv195
      355     13/10/2019 12:01:17 am            RSM_HPC_VERSION=195
      356     13/10/2019 12:01:17 am            RSM_HPC_STAGING=\MainCADRSMStagingeubgp21n.ezb
      357     13/10/2019 12:01:17 am            RSM_HPC_LOCAL_PLATFORM=Windows
      358     13/10/2019 12:01:17 am            RSM_HPC_CLUSTER_TARGET_PLATFORM=Windows
      359     13/10/2019 12:01:17 am            RSM_HPC_STDOUTFILE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      360     13/10/2019 12:01:17 am            RSM_HPC_STDERRFILE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      361     13/10/2019 12:01:17 am            RSM_HPC_STDOUTLIVE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      362     13/10/2019 12:01:17 am            RSM_HPC_STDERRLIVE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      363     13/10/2019 12:01:17 am            RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=C:Program FilesANSYS Incv195RSMConfigscripts
      364     13/10/2019 12:01:17 am            RSM_HPC_SCRIPTS_DIRECTORY=%AWP_ROOT195%RSMConfigscripts
      365     13/10/2019 12:01:17 am            RSM_HPC_SUBMITHOST=localhost
      366     13/10/2019 12:01:17 am            RSM_HPC_STORAGEID=    2e240152-9c98-4c8b-b806-5ccbbda6db14    Mechanical=LocalOS#localhost$\MainCADRSMStagingeubgp21n.ezb    Saturday, October 12, 2019 11:01:15.288 AM    True
      367     13/10/2019 12:01:17 am            RSM_HPC_PLATFORMSTORAGEID=\MainCADRSMStagingeubgp21n.ezb
      368     13/10/2019 12:01:17 am            RSM_HPC_NATIVEOPTIONS=
      369     13/10/2019 12:01:17 am            ARC_ROOT=C:Program FilesANSYS Incv195RSMConfigscripts....ARC
      370     13/10/2019 12:01:17 am            RSM_HPC_KEYWORD=ARC
      371     13/10/2019 12:01:17 am            RSM_HPC_COMMAND=clusterjob_9f9da426-822a-4234-a55a-2a8fc2bef7c8.bat
      372     13/10/2019 12:01:17 am            RSM_HPC_PARSE_MARKER=START
      373     13/10/2019 12:01:17 am
      374     13/10/2019 12:01:17 am     ArcMaster process running as NT AUTHORITYSYSTEM
      375     13/10/2019 12:01:17 am     ArcNode process running as NT AUTHORITYSYSTEM
      376     13/10/2019 12:01:17 am     Skipping autostart because Master processes is started as a service.
      377     13/10/2019 12:01:17 am     Job was successfully submitted as <9>
      378     13/10/2019 12:01:17 am     External cluster command: parseSubmit
      379     13/10/2019 12:01:17 am        Cluster command before expansion: %RSM_PYTHON_EXE% -B -E "%RSM_HPC_SCRIPTS_DIRECTORY_LOCAL%/arcParsing.py" -submit %RSM_HPC_PARSE_MARKER%
      380     13/10/2019 12:01:17 am        Final cluster command: C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe -B -E "C:Program FilesANSYS Incv195RSMConfigscripts/arcParsing.py" -submit START
      381     13/10/2019 12:01:17 am        Working directory : \MainCADRSMStagingeubgp21n.ezb
      382     13/10/2019 12:01:17 am        Variables:
      383     13/10/2019 12:01:17 am            RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
      384     13/10/2019 12:01:17 am            RSM_IRON_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesIronPython
      385     13/10/2019 12:01:17 am            RSM_PYTHON_EXE=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepythonpython.exe
      386     13/10/2019 12:01:17 am            RSM_TASK_WORKING_DIRECTORY=\MainCADRSMStagingeubgp21n.ezb
      387     13/10/2019 12:01:17 am            RSM_USE_SSH_LINUX=False
      388     13/10/2019 12:01:17 am            RSM_QUEUE_NAME=default
      389     13/10/2019 12:01:17 am            RSM_CONFIGUREDQUEUE_NAME=Default
      390     13/10/2019 12:01:17 am            RSM_COMPUTE_SERVER_MACHINE_NAME=Maincad
      391     13/10/2019 12:01:17 am            RSM_HPC_JOBNAME=Mechanical
      392     13/10/2019 12:01:17 am            RSM_HPC_DISPLAYNAME=Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
      393     13/10/2019 12:01:17 am            RSM_HPC_CORES=12
      394     13/10/2019 12:01:17 am            RSM_HPC_DISTRIBUTED=TRUE
      395     13/10/2019 12:01:17 am            RSM_HPC_NODE_EXCLUSIVE=FALSE
      396     13/10/2019 12:01:17 am            RSM_HPC_QUEUE=default
      397     13/10/2019 12:01:17 am            RSM_HPC_USER=MAINCADUser
      398     13/10/2019 12:01:17 am            RSM_HPC_WORKDIR=\MainCADRSMStagingeubgp21n.ezb
      399     13/10/2019 12:01:17 am            RSM_HPC_JOBTYPE=Mechanical_ANSYS
      400     13/10/2019 12:01:17 am            RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY=C:Program FilesANSYS Incv195
      401     13/10/2019 12:01:17 am            RSM_HPC_VERSION=195
      402     13/10/2019 12:01:17 am            RSM_HPC_STAGING=\MainCADRSMStagingeubgp21n.ezb
      403     13/10/2019 12:01:17 am            RSM_HPC_LOCAL_PLATFORM=Windows
      404     13/10/2019 12:01:17 am            RSM_HPC_CLUSTER_TARGET_PLATFORM=Windows
      405     13/10/2019 12:01:17 am            RSM_HPC_STDOUTFILE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      406     13/10/2019 12:01:17 am            RSM_HPC_STDERRFILE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsmout
      407     13/10/2019 12:01:17 am            RSM_HPC_STDOUTLIVE=stdout_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      408     13/10/2019 12:01:17 am            RSM_HPC_STDERRLIVE=stderr_9f9da426-822a-4234-a55a-2a8fc2bef7c8.live
      409     13/10/2019 12:01:17 am            RSM_HPC_SCRIPTS_DIRECTORY_LOCAL=C:Program FilesANSYS Incv195RSMConfigscripts
      410     13/10/2019 12:01:17 am            RSM_HPC_SCRIPTS_DIRECTORY=%AWP_ROOT195%RSMConfigscripts
      411     13/10/2019 12:01:17 am            RSM_HPC_SUBMITHOST=localhost
      412     13/10/2019 12:01:17 am            RSM_HPC_STORAGEID=    2e240152-9c98-4c8b-b806-5ccbbda6db14    Mechanical=LocalOS#localhost$\MainCADRSMStagingeubgp21n.ezb    Saturday, October 12, 2019 11:01:15.288 AM    True
      413     13/10/2019 12:01:17 am            RSM_HPC_PLATFORMSTORAGEID=\MainCADRSMStagingeubgp21n.ezb
      414     13/10/2019 12:01:17 am            RSM_HPC_NATIVEOPTIONS=
      415     13/10/2019 12:01:17 am            ARC_ROOT=C:Program FilesANSYS Incv195RSMConfigscripts....ARC
      416     13/10/2019 12:01:17 am            RSM_HPC_KEYWORD=ARC
      417     13/10/2019 12:01:17 am            RSM_HPC_COMMAND=clusterjob_9f9da426-822a-4234-a55a-2a8fc2bef7c8.bat
      418     13/10/2019 12:01:17 am            RSM_HPC_PARSE_MARKER=START
      419     13/10/2019 12:01:17 am            RSM_HPC_PRIMARY_STDOUT=ArcMaster process running as NT AUTHORITYSYSTEM
      420     13/10/2019 12:01:17 am     ArcNode process running as NT AUTHORITYSYSTEM
      421     13/10/2019 12:01:17 am     Skipping autostart because Master processes is started as a service.
      422     13/10/2019 12:01:17 am     Job was successfully submitted as <9>
      423     13/10/2019 12:01:17 am            RSM_HPC_PRIMARY_STDERR=
      424     13/10/2019 12:01:17 am
      425     13/10/2019 12:01:17 am     JobId was parsed as: 9
      426     13/10/2019 12:01:17 am     Job submission was successful.
      427     13/10/2019 12:01:22 am     Job is running on hostname Maincad
      428     13/10/2019 12:01:22 am     Job user from this host: User
      429     13/10/2019 12:01:22 am     Starting directory: \MainCADRSMStagingeubgp21n.ezb
      430     13/10/2019 12:01:22 am     Reading control file \MainCADRSMStagingeubgp21n.ezbcontrol_9f9da426-822a-4234-a55a-2a8fc2bef7c8.rsm ....
      431     13/10/2019 12:01:22 am     Correct Cluster verified
      432     13/10/2019 12:01:22 am     Cluster Type: ARC
      433     13/10/2019 12:01:22 am     Underlying Cluster: ARC
      434     13/10/2019 12:01:22 am        RSM_CLUSTER_TYPE = ARC
      435     13/10/2019 12:01:22 am     Compute Server is running on MAINCAD
      436     13/10/2019 12:01:22 am     Reading commands and arguments...
      437     13/10/2019 12:01:22 am        Command 1: %AWP_ROOT195%SECSolverExecutionControllerrunsec.bat, arguments: , redirectFile: None
      438     13/10/2019 12:01:22 am     Running from shared staging directory ...
      439     13/10/2019 12:01:22 am        RSM_USE_LOCAL_SCRATCH = False
      440     13/10/2019 12:01:22 am        RSM_LOCAL_SCRATCH_DIRECTORY =
      441     13/10/2019 12:01:22 am        RSM_LOCAL_SCRATCH_PARTIAL_UNC_PATH =
      442     13/10/2019 12:01:22 am     Cluster Shared Directory: \MainCADRSMStagingeubgp21n.ezb
      443     13/10/2019 12:01:22 am        RSM_SHARE_STAGING_DIRECTORY = \MainCADRSMStagingeubgp21n.ezb
      444     13/10/2019 12:01:22 am     Job file clean up: True
      445   &nb
    • JakeC
      Please go to the staging directory from the command line on maincad (using the local path/drive letter) and run the following from the command line:
       C:Program FilesANSYS Incv195ansysbinwinx64ANSYS195.exe -b nolist -s noread -p ansys -mpi intelmpi -i remote.dat -o solve.out -dis -machines maincad:4:cluster01:4:cluster02:4 -dir "//MainCAD/RSMStaging/eubgp21n.ezb"
      Please send a screenshot of the output.
      Also make sure that IntelMPI is installed on all machines, and that you have cached the IntelMPI password on each machine.
      Are these machines on domain? (It doesn't look like it from the log)
      You could also try IBM MPI instead of IntelMPI (that won't require a password to be cached)
      To do that, go into the Mechanical Solve Process Settings, select the setting you are using to submit the job with, click Advanced...
      In "Additional Command line arguments" enter:
      -mpi ibmmpi
      Then try resubmitting.
      Make sure that IBM MPI is installed on each machine.
      If it is not, you can run the installer from:
      C:Program FilesANSYS Incv195commonfilesMPIIBM9.1.4.5WindowsPlatform_MPI-9.1.4.5-hpc.x64.exe
      Thank you,
      Jake
    • kolyan007
      Thanks Jake, I got it working with IBM MPI and non-localhost HPC resource. All good now
Viewing 26 reply threads
  • The topic ‘Distributed solver’ is closed to new replies.
