TAGGED: -Structured-Meshing, fea, meshing, spaceclaim
August 20, 2024 at 1:18 pm
Saad Sultan
SubscriberHello Everyone,
I had been following a tutorial "Workshop2: Basic Mesh Control" with an example of Disk_Seal geometry in the course "ANSYS Spaceclaim Meshing for FEA. Whenever I use Match Control for meshing, the vertices are mapped incorrectly. I have figured out where the vertices should be located but I'm unable to move the mesh vertices.
Here it the original geometry of Disk:
I followed the instructions to generate a mesh like:Â
but actually what I get is:Â
I'm quite aware where should these red and green vertices be located but they are not mapped correctly. How can I move these vertices onto the target body ?
best regards, -
August 21, 2024 at 9:38 am
Deepak
Ansys EmployeeÂ
I tried meshing the same model, and it works fine. Please cross-check whether you have given any size controls to the model before meshing.Â
Refer: Aligning Block Vertices (ansys.com)
Thanks,
Deepak
5794
1305
