Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Partial slip for rarefied flow regime › Reply To: Partial slip for rarefied flow regime
August 13, 2024 at 4:42 pm
That's the problem: the solver has the model as off and the GUI thinks it's on. If you can turn the model on try and see if you can & then turn it off. Otherwise read the mesh into a new Fluent session and see if that works.Â
