Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Problem converting U,V coordinates to Theta and phi › Reply To: Problem converting U,V coordinates to Theta and phi
August 12, 2024 at 8:30 am
Niki Papachristou
Hi David,
Thank you for reaching out to us and posting your question here. To be honest I am a little bit confused on what you are trying to achieve here. The second image is from our vizualiser while the first is from your script?Â
I think that if you try to create a polar graph as it is on he second image you will get the same results.
Kind Regards,
Niki
