August 11, 2024 at 3:34 pm
Noura Mansour
SubscriberI used ansys_aas toolbox to link between ansys workbench and matlab but i'm confused of how can the matlab reads the chart in ansys and make optimization to get minimum error between desired and actual curves
August 12, 2024 at 4:10 pm
Mike Rife
Ansys EmployeeHi Noura
Please give the version of the Ansys product you are using whenever you ask a question here (can really help determine how to answer a question). Also what do you mean be '...reads the chart in ansys...'? Ansys is not a product so I'm not sure what you are asking here. I guess about WB Mechanical? If so which chart? A scree shot may help.
Are you using the method given by MathWorks on their community page? If so I'd pose this question there.
If you are using the MathWorks toolbox you may want to explore the world of PyAnsys instead here. PyAnsys is a set of language libraries, right now for Python (mainly), that allows us to interact with different Ansys products. Â
Mike
August 12, 2024 at 8:35 pm
Noura Mansour
SubscriberI'm working on ansys workbench and it's version is ansys 2023 R1 .. i mean by chart the chart between force and displacement cause I want to make optimization to reduce the error between the desired force displacement curve and the force displacement curve obtained from ansysÂ
https://www.mathworks.com/matlabcentral/answers/160210-how-can-i-run-ansys-from-matlab#answer_2500
79
5664
1890
1419
1304
