Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Doubts about field enhancement E/E0 and field normalization › Reply To: Doubts about field enhancement E/E0 and field normalization
Hi Giovanni,
Can I say that the maximum value reported of 124 is actually the field enhancement E/E0?Â
Yes, I would say that 124 is the field enhancement.
In linear simulation, we do not actually need to change the amplitude of the source. The field enhancement will not depend on the value of the amplitude. As you mentioned, it is going to remain 124 even when you reduce the amplitude by 0.5. The absolute power will depend upon the amplitude of the source. But, if you know the power for any given amplitude, you can easily determine the power for other amplitudes by simple multiplication. So, in any case (linear simulation), I would recommend you to keep the source amplitude 1, and then you can use the field distribution to calculate the field enhancement.
Amrita
