Photonics
Photonics
CHARGE: Simulation Halting at 8.5 V During Voltage Sweep from 0 V to 12 V
    • ph23resch01002
      Dear Sir/Madam,
      I am currently using Lumerical Charge to simulate an active metasurface unit cell. I have attached a picture of the unit cell for your reference. I will briefly describe the unit cell structure:
      The unit cell consists of a SiO2 substrate on which a Si slab is placed. On top of the Si slab, there is a GaAs layer, followed by an Al2O3 layer, and finally Si resonators. The voltage is applied between the Si resonator and the GaAs layer using the electrical connection boundary condition.
      I attempt to sweep the voltage from 0 V to 12 V to observe the charge distributions. The simulations run smoothly up to 8.5 V; however, beyond this point, the simulation halts and displays the attached error.
      I have also checked the online references for troubleshooting this issue and made the following adjustments in the Charge Solver advanced settings:
      1. Solver type: Kept as Gummel.
      2. Global iteration limit: Increased from 40 to 50.
      3. Gradient mixing: Changed from Disabled to Conservative.
      4. Update limiting values: Decreased.
      Despite these changes, the problem persists. Could you please assist in resolving this issue?
      Thank you for your support.
    • Niki Papachristou
      Hi Bharathy,
      Thank you for reaching out to us. For you case may I ask you whether you have checket your CHARGE simulation using the Partitioned volumes in finite element solvers - Simulation object?
      After partitioning the sumulation if you have a none in one of your domains means that you dont have a material there and the simulation might be stoping for that.
      Let me know if that's the case.
      Kind Regards,
      Niki
