Ansys Learning Forum Forums Installation and Licensing Ansys Products Help-Boolean Operation Failed Reply To: Help-Boolean Operation Failed
That looks like a 2d model. You may find it will work if you extrude the fault and then split with that volume/bounding faces. Booleans can be a little messy in 2d as contact can be zero because the surfaces have no thickness.
