Ansys Learning Forum Forums Discuss Simulation General Mechanical How to define a rigid surface for a solid Reply To: How to define a rigid surface for a solid
Ashish Khemka
Is the driver part a rigid body? Genereally mesh is generated for surfaces on rigid body which are in contact. Turn off the weak spring. You can specify rotation on the rigid body via remote displacment.
Ashish Khemka
