Help for solving “invalid geometry”
    • KeWu
      Hi there,
      I got an error of "invalid geometry" before running the simulation.
      Could you give me some instructions about it?
      Please see the attached.
      Thanks in advance,
      Ke Wu
      In ANSYS 2019 R2, if you right click on the message of invalid geometry, the pop-up menu says Go to object.
      You can see that the four Deformation Probes under the Solution branch have lost the Geometry Selection.  Reselect the geometry and it will solve.
    • KeWu
      Problem solved!
      Thank you so much!!
      Ke
    • mohammad.sajid
      Hi KeWu,
      I couldn't find the deformation probes. Also I am using shell element in my geometry doe the solver being Steady State Thermal-Electric Analysis. Could that be the reason?
  • The topic ‘Help for solving “invalid geometry”’ is closed to new replies.
