Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Defining custom material based on ASME BPVC Div. 2 › Reply To: Defining custom material based on ASME BPVC Div. 2
August 2, 2024 at 1:32 pm
Armin
Hi Sigurd,
You should use plastic strain versus true stress to define the hardening (stress-strain) curve of your metal. Initial yield stress (0.2% rule) and ultimate tensile strength are commonly defined based on engineering stress.
