Ansys Learning Forum Forums Discuss Simulation General Mechanical Importing Boundary Conditions from INP File Reply To: Importing Boundary Conditions from INP File
Cari Whyne
Hi! Thanks for this! I looked into my INP file and found that unloaded_seg_Mesh-1 was defined as an instance here. Then the first column of boundary conditions follow the format {instance name}.{node ID}. Not sure why these boundary conditions would not be compatable in Ansys, and what I should do to modify them.
