August 1, 2024 at 7:00 pm
Pawel Cebula
SubscriberI'm working on a parametric study (Static Structural) for a submodel of a main Statuc Structural component in the same Workbench project.
The main Structural Component has results up to date, but some of its feeding components need update.
When I try solving the design point, it causes domino effect update on entire project file which in my case takes ages. Is there a way to solve design point without updating the whole project file? -
August 2, 2024 at 11:34 am
ashish.khemka
Forum ModeratorHi,
Try selelcting the requireried analysis system and then click on update. For example you have 5 analysis systems (A to E) and you want to update just 3 of them then select one and ctrl and select the remaining two and then hit on update button.
Ashish Khemka
