Ansys Learning Forum Forums Discuss Simulation General Mechanical User Defined Result Reply To: User Defined Result
Dustin Lochmüller
Thank you for your detailed answer. Unfortunately, I am unable to make it work.
In this picture you can see the analysis I am currently using. I generate the path I want to use in static structural. The solid I intend to apply to the geometry parameter is the solid imported from the mechanical model. A named selection contains this body, how can I use the named selection to assign the body to the Geometry parameter?
And another thing I can't find a solution for currently: Is there a way to export the user defined results data in table form using scripting? Like in this picture
Thanks for helping
Dustin
