Ansys Learning Forum Forums Discuss Simulation General Mechanical Consultation about Exporting Data Reply To: Consultation about Exporting Data
Aniket Chavan
Assuming you are using Ansys Mechanical.
  1. add a result scoped to a single body instead of "all bodies" that is default.
  2. can you elaborate on this one?
  3. yes, please check https://catalog.ansys.com/product/5b3bc6857a2f9a5c90d32e7f/multi-object-expor it has source code, which you can use for reference to tweak to your needs
  4. use different exports for each body?
  5. 2.28.4. Selecting Nodes and Elements by ID (ansys.com)
-Aniket
Forum Rules & Guidelines
