Ansys Learning Forum Forums Discuss Simulation General Mechanical Getting the error while performing a fracture analysis Reply To: Getting the error while performing a fracture analysis
David Weed
Hi Sanjay,
For fracture mechanics simulations, contact elements are not allowed in the crack mesh region as your screenshots show. As an approximation to the sliding behavior that you want between those two surfaces, you can consider splitting the faces in order to partition the contact pairs so that they are outside of the scope of the crack mesh region but also cover enough of the surfaces to allow sliding.
