Ansys Learning Forum Forums Discuss Simulation Fluids Meshing thickness of the shell (Surface from Faces) Reply To: Meshing thickness of the shell (Surface from Faces)
Federico
Hello Farah,
looks like the second pictured mesh (yellow) used inflation layers from the inside boundary. You can tell by the fact that the inside edge has prismatic cells but the outside should triangles. That could be an option for you.
