Ansys Learning Forum Forums Discuss Simulation Electronics Axial Flux motor 3D simulation, out of memory issue in Ansys Maxwell Reply To: Axial Flux motor 3D simulation, out of memory issue in Ansys Maxwell
Reshmi Raghavan
Hello Junaed,
As you mentioned the model is taking around 94% memory usage, this is the reason for failure of the analysis. The solution for the same is to either increase the RAM and another is to simplify the problem which is being solved.
In the initial magnetostatic analysis are you exciting the windings with a current?
You can make the model segemented if not done. This would help in generating a refined mesh.
