Ansys Learning Forum Forums Discuss Simulation Fluids Volume Fraction too Low. How to Improve? Reply To: Volume Fraction too Low. How to Improve?
abdullahhassan
Thank you Sir,
I understand your point for using HTC value. I will try this way and will let you know.
1- shadow wall will be set to coupled as shown below:
2- If I choose coupled at the "outside" tube wall (wet tube side boundary), how can I choose HTC ? below is the BC setup.
3- last thing, what is meant by re-read the inlet pressure?
