TAGGED: .stl-to-ansys, 3d-geometry, 3dmodel, ansys-cfx, error, mesh, spaceclaim, workbench
July 29, 2024 at 5:15 pm
ds286
SubscriberHello! I am importing a STL file for Fluent analysis. I have used SKIN Surface and repairing the sharp edges. I havent been able to accurately import it to use it. What strategies should I use??!
When I first tried to import it I was directly converting it to CAD in SC [SpaceClaim] but it had a lot of protrusions/sharp edges that the software cannot fix. They were fixed separately and I imported the STL again but then it appeared an error that it coudnt generate because of "14 open edges". I have also tried Quad Remesh in Rhino and downloading it as an IGS file but it didnt work either.
July 30, 2024 at 6:36 am
Keyur Kanade
Ansys EmployeeI assume you have a STL file which you want to use for fluid analysis in Fluent.Â
STL contanins all faceted data. For such files there are 2 approaches.Â
- Use fault tolerant workflow in Fluent Meshing to generate mesh. Please check ANSYS Fluent: Fault Tolerant Meshing Workflow - YouTube
- Use reverse engineering in SpaceClaim to generate geometry from STL and then proceed to mesh that geometry. Please check Reverse Engineering with ANSYS SpaceClaim - YouTube
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
August 14, 2024 at 3:38 pm
ds286
SubscriberThank you Keyur! I have tried the reverse engineering, (on my previous comment I used the AutoSkin Surface in Space Claim, but then it appeared an error that it coudn't generate because of "14 open edges"). So, I have moved on to using your first suggestion of fault tolerant workflow. I am using it currently (IT IS WORKING!), if I am doing external flow, how would you recommend is the best option for extracting edge features?
How can I improve the fidelity of the geometry (changing mesh default field ratio perhaps)?
So far the geometry is not acurrately captured.
I look forward to continuing this conversation! Thank you
- The topic ‘STL Convertion’ is closed to new replies.
5654
1890
1414
1303
