3D Design
3D Design
Cuda downgrade to suit Discovery 2024 R1
    • Jon Powell
      I have CUDA 12.2 instaled on a Windows machine but Discovery requires 11.5   What is the safest way to downgrade from 12.2 to 11.5?
    • Devendra Badgujar
      Hello Jon,
      I don't think there is need to downgrade. Are you facing any issues while installing Discovery or when opening?
      Devendra
    • Jon Powell
      Discovery installed aleady.  This is is simply the output from the compatibility checker, I ran it after Discovery failed to start. Discovery 2023 R1 has worked on this machine previously.
    • Devendra Badgujar
      Hello Jon,
      I checked with the developers and the issue is you have 2 graphics cards that support rendering, and Discovery is having trouble with the multi-GPU setup.
      Please go into Nvidia settings and assign a specific card to Discovery for rendering. Let me know if that helps.
      Instructions:
      Go to the NVIDIA Control Panel (by right-clicking on your desktop > NVIDIA Control Panel), go to the Manage 3D Settings tab.
      There, under Program Settings, make sure you Add Discovery as a program that is using the best specs of the NVIDIA driver to a specific one.
      Devendra
  • The topic ‘Cuda downgrade to suit Discovery 2024 R1’ is closed to new replies.
