The result data for NL is not contained in the result file.
    • 1617836513
      My model uses bilinear isotropic strength and in the results the stress values have exceeded the yield strength and entered the plastic phase. I turned on the large deformation setting, why I still can't calculate the accumulated plastic strain, error"The result data for NL is not contained in the result file.".
    • 1617836513
      I have knew it.
  • The topic ‘The result data for NL is not contained in the result file.’ is closed to new replies.
