July 26, 2024 at 5:51 am
Zwernjayden
SubscriberI'm using dpm, and the properties of Lox default to vaporization temp: 55k, boiling point: 90.2k, and I need to enter the vapor pressure manually. Do I need to adjust these based on the domain pressure its being injected into? And is the vapor pressure of Lox just 1atm because its naturally a vapor?
August 6, 2024 at 1:31 pm
Prashanth
Ansys EmployeeHi, you can use DEFINE_DPM_PROPERTY for setting vapor pressure as you like, and make vaporization as a function of pressure
- The topic ‘Lox Properties’ is closed to new replies.
Ansys Innovation Space
1013
956
858
797
