Ansys Learning Forum Forums Installation and Licensing Ansys Products ANSYS Mechanical UI Not Displaying Reply To: ANSYS Mechanical UI Not Displaying
ashish.khemka
Can you try doing an appdata reset? To do a APPDATA reset:
a. Completely close out ANSYS (any and all open projects)
b. Open a Windows Explorer window and in the bar at the top input: %APPDATA%
c. Go into the Ansys folder
d. Rename the v22.1 folder to v22.1_old (so that there isn't a folder named v22.1 - this is for v2022R1)
e. Launch ANSYS and all your setting will be reset.
Please see if this helps.
Ashish Khemka
