Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ACP: How to disable Drop-off on middle surface ? › Reply To: ACP: How to disable Drop-off on middle surface ?
July 23, 2024 at 8:21 am
Thomas Hirche
Hi Daniel,
you could export the solid model without writing degenerated elements. You can find this option in the Export tab of the Solid Model Properties. This is a global control and would remove all degenerated elements in your model.
If you want to model two disconnected pipes you might consider to create two separate solid models. Please also consider to file a Service Request if you need further help.
Regards
Thomas
