Electronics
Electronics
Wrapsheet error
    • fanty
      After performing Wrapsheet, I received the following errors (Model and error message attached). Could anyone tell me what I need to correct to make this work?
      The pole error: does this mean the sheet cannot be at a certain location?
    • Praneeth
      Thank you for reaching out to the Ansys learning forum.
      I was not able to replicate your case. Please share the geometry properties defined for the sphere and 2D sheet to help us serve you better.
      Best regards,
      Praneeth.
  • The topic ‘Wrapsheet error’ is closed to new replies.
