Ansys Learning Forum Forums Discuss Simulation General Mechanical How to connect two nodes (Ansys workbench) Reply To: How to connect two nodes (Ansys workbench)
Rahul Kumbhar
You may split the faces in Geometry editor and then define contact for the required surafce region. It is also possible to split the surface in Mechanical using Virtual Topology.
Best Regards
Rahul
