July 21, 2024 at 4:49 am
Kevin Chen
SubscriberI have bulit a cylindrical cell zone for porous zone of metal porous medium recevied radiation energy from outside,and I want to know that how much energy transfer from convention of metal porous.
After calculation finished,I just could know the temperature of fluid but temperature of solid.Does anyone know how to get the results of solid temperature,I will appreciate you so much.
July 22, 2024 at 12:26 pm
Forum ModeratorYou did read the documentation section that explains porous zones aren't effected by radiation as Fluent doesn't "see" the metal in the zone? Also, that the solid and fluid are the same temperature unless you used the non-equilibrium option?
- The topic ‘FLUENT porous zone solid temperature problem’ is closed to new replies.
1565
1386
1241
