July 19, 2024 at 10:24 amN. M.Subscriber
Hello Everyone,
I am a geometry in Design Modeler, imported from a .stp file.
This geometry is formed by 53940 bodies, as you can see in the attached figure.As can be inferred, work with this geometry is very demanding for the computer.
I need only one of the 53940 bodies, so all the bodies except the one I need are suppressed, but also in this scenario the software is slow.
There is a way to export only the body I need between all the 53940 bodies, in order to reload only it in another Design Modeler?
Thank you 😀
July 19, 2024 at 11:21 amEssenceAnsys Employee
Why don't you delete all other bodies and keep just the one body you need? You can have copies of the original geometry, in case if something goes wrong.
July 22, 2024 at 3:41 pmN. M.Subscriber
Hello.
Yes, I subsequently tried deleting all the other bodies, and the software sped up. It took some time, but in the end, it seemed to work.ÂThank you anyway for your reply. 😀
- The topic ‘Export a single body from a multi body geometry’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Script error Code: 800a000d
- Cyclone (Stairmand) simulation using RSM
- Fluent fails with Intel MPI protocol on 2 nodes
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
543
523
225
209
