Ansys Learning Forum Forums Discuss Simulation Fluids Initializing design points with different solution files Reply To: Initializing design points with different solution files
V.P
Hi Farshid,
Could you check if the Initial values definition section is present under the Execution Control settings in CFX-Pre? You can find this in Insert > Solver > Execution Control > Initial Values > Initial Values Specification. You can use this to specify initial values.
