July 17, 2024 at 12:29 pm
Raoul Abas
SubscriberHello,
we have trouble to run dyna mpp since our HPC is migrated from Centos to Redhat 8.8. I read the same issue in this closed post Trouble running MPP LS- DYna 10.20 on Red Hat 8.4 (ansys.com)
Is it possible for us to also get R13.1 sse2-intelmpi, each single and doube precision that recompiled with ifort 16.4.258?
Raoul
July 19, 2024 at 6:41 pm
igandiko
Ansys EmployeeR13.1 builds are using ifort 19 (it should say on the exe filename or d3hsp banner) so I don't think its the same issue. What error do you get? Which version of Intel MPI are you using? I would try the latest version of IMPI.
July 22, 2024 at 11:03 am
Raoul Abas
SubscriberThe run is stopped at very beginning and not even creating d3hsp.
I got this message:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
ls-dyna_mpp_s_R13 000000000771A243 Unknown Unknown Unknown
libpthread-2.28.s 000014E480A7CCF0 Unknown Unknown Unknown
libc-2.28.so 000014E47F187646 strtok_r Unknown Unknown
libmpifort.so.12. 000014E4807F4561 __I_MPI___intel_s Unknown Unknown
libmpi.so.12.0 000014E47FD83BE5 Unknown Unknown Unknown
libmpi.so.12.0 000014E47FD868F4 Unknown Unknown Unknown
libmpi.so.12.0 000014E47FD2764B Unknown Unknown Unknown
libmpi.so.12 000014E47FD14BDB MPI_Init Unknown Unknown
libmpifort.so.12. 000014E48079A240 MPI_INIT Unknown Unknown
ls-dyna_mpp_s_R13 000000000041D90A MAIN__ 3794 lsdyna.f
ls-dyna_mpp_s_R13 0000000000417362 Unknown Unknown Unknown
libc-2.28.so 000014E47F121D85 __libc_start_main Unknown Unknown
ls-dyna_mpp_s_R13 0000000000417269 Unknown Unknown UnknownMPI:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/ansys_inc/v232/commonfiles/MPI/Intel/2018.3.222/linx64/lib
/ansys_inc/v232/commonfiles/MPI/Intel/2018.3.222/linx64/bin/mpiexec
It seems that it can't get the correct library
- The topic ‘Trouble MPP dyna running in Redhat 8.8’ is closed to new replies.
5649
1885
1404
1303
