How to prescribe displacements for a set of multiple nodes simulteanouly?
    • asceduardo
      I am investigating the dynamical behaviour of a beam using Transient Structural analysis. In my study, I need to prescribe specific displacements for dozens of nodes simultaneously. Prescribing displacements node per node would require too much time and effort, and a named selections give the same displacements for all nodes at once. Instead, I would like to create something like this:
      Node | Displacement
      001: 0.00
      002: 0.01
      003: 0.03
      010: 0.01
      100: 0.02
      (etc)
      Does anyone know how can I create a set of displacements like this? Thanks in advance.
    • ashish.khemka
      You can use External Data module to import the data from an excel or other text file into Transient Structural Analysis.
      External Data (ansys.com)
      Ashish Khemka
    • dlooman
      It might be possible if you have a value for each node in the named selection in a two column text file of node and values separated by a space or comma.  DLIST can be used afterward to check if it worked.  Mid-side nodes might interfere with this process.
      *dim,d_vals,table,100,,,node         ! For 100 values
      *tread,d_vals(1),filename,txt          ! read node and displacement values from file
      cmsel,s,named_selection
      d,all,ux,%d_vals%
      allsel
      dlist
    • asceduardo
      Thank you. I have successfully imported external data from Excel (".csv") into my model following the instructions you gave me. However, for some reason Ansys will only accept static forces/displacements. To perform dynamical simulations, data must be dependent of time:
      X-Coordinate | Displacement
      0.00 | 0.000
      0.01 | 0.001*sin(time)
      0.02 | 0.003*sin(time)
      (etc)
      Typing "sin(time)" works for displacements/forces defined inside Ansys, but it does not work for external data. Do you know how can I solve that?
    • dlooman
      If you want the displacements to be interpreted as sinusoidal do a harmonic analysis:
      antype,harm
      harf,value        ! frequency of sinusoid in hz
      • asceduardo
        Is there any form of doing that in Transient Analysis? I think Harmonic Analysis does not fit my objetive because I would like to include any functions of time and not only sinusoidal ones.
    • dlooman
      Probably not.  How many cycles do you need to run?
Viewing 5 reply threads
  • The topic ‘How to prescribe displacements for a set of multiple nodes simulteanouly?’ is closed to new replies.
