Incremental static analysis in ANSYS Mechanical APDL
    • aamirsardari
      Hi ANSYS community,
      I am trying to run incremental static analysis in ANSYS Mechanical APDL. I am not sure how to write the code using a loop command (using “*do”). I need to write a loop command (rather than directly solving by defining the number of subsets etc) because after each solved step, I need to review the stresses and strains in the model and use the ekill command if the threshold is exceeded.
      A short example of my script is below. I like to apply a displacement of 20mm to the selected nodes in 100 steps. However, in my current code, in the first load step the 20mm is applied, rather than 20/100 = 0.2mm.
      Could someone please advise how I can correct my script?
      Many thanks,
      Anita
      !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Apply load on selected nodes !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      NSLA, R,1
      NSEL,R,LOC,X,-100, 100
      NSEL,R,LOC,Y,300
      NSEL,R,LOC,Z,27
      CM, n0, NODES
      D,n0,UY,20, , , , , , , , ,
      ALLSEL,ALL
      !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Define Solution Controls !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      /SOLU
      !total number of steps for solve
          steps=100
          TIME_END=1
          timeinc=TIME_END/steps
          time,timeinc
          solve
      *do,ICOUNT,1,steps-1
        /solu
        allsel,all
        time,timeinc*ICOUNT+timeinc
        solve
        finish
      *enddo
    • ashish.khemka
      Instead of defining loadsteps you can define equal substeps. Also, refer to the following verification maula from Ansys Help which might help ypu:
      Ansys Mechanical APDL Verification Manual
      NSUBST (ansys.com)
      Ashish Khemka
    • aamirsardari
      Hi Ashish,
      Thank you very much for the suggested references. I am unable to find an example in the Verfication Manual for which a loop is used to incrementally increase the applied load.
      I am able to use NSUBS to run the analysis successfully, however, this doesn't allow me to create a loop command where I can check the stresses at each substep in order to implement ekill if required.
      Would you please be able to provide an example where the load is applied incrementally but at each substep it is possible to run a *do command to check element stress and execute ekill if the stress exceeds the threshold?
      Many thanks,
      Anita
    • ashish.khemka
  • The topic ‘Incremental static analysis in ANSYS Mechanical APDL’ is closed to new replies.
