TAGGED: #fluent-#ansys, #fluent-#cfd-#ansys, ansys-cfd-post, fluent
July 13, 2024 at 7:39 pm
Chris Roberts
SubscriberHello,
I am running a transient simulation in Fluent. I am trying to collect mass flow rate data through a tube. I am made a plane that is a perpendicular to the center of the tube to capture to flow velocity on the contour. The simulation runs without any issues and the save gets saved for a video file. However when I try to save the video file to export it I am getting this error. I can view/play the video without any issue in fluent but when I save it I run into this error. If anyone can suggest anything that I might have missed in the settings or incorrectly setting up a plane that would be very helpful. Thank you kindly all.
July 16, 2024 at 12:40 pm
Federico
Ansys EmployeeHello Chris,Â
can you try writing the video to a different location? One with a shorter path length
- The topic ‘Video Export Error in Fluent’ is closed to new replies.
