July 12, 2024 at 7:38 am
Huadong Sun
Ansys EmployeeStatic Structural 计算的变形后的几何导入spaceclaim
July 12, 2024 at 7:39 am
Huadong Sun
Ansys Employee•Follow the below procedure:-1. First run Static Structural with solution containing desired deformation results. In Analysis setting’s keep Save DB option on.-2. Link solution to a new Mechanical Model, and then link this Mechanical Model to Geometry.-3. Update the Mechanical Model & open the geometry in SpaceClaim.-4. Generate the part in SpaceClaim, Click on file and export the geometry as a .stp format.-5. Import the .stp format geometry in SpaceClaim (standalone system) and use save as option to save the geometry as .dwg file format.
- 主题 ‘Static Structural 计算的变形后的几何导入spaceclaim’ 已关闭新回复.
1307
